Project Blackbird is underway - pics (56k go away)
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Another new paintjob in the making. For the most part, the original paint was in great condition, only a few spots where the paint was going bad. Clearcoat overall was good, but there were a number of lsmall chips in the clear in a lot of places. Luckily nearly all of them were only in the clear and not into the base. A couple of dents that will be pulled and filled, then 4 coats of fresh black paint. Not seen in the photos is the markers, parking, and tail lights coming off, as well as the emblems, front grill, and lower front gfx.
More photos to come.
A while back a rust spot popped up on the A-pillar down near the bottom. We originally thought it was just surface rust. Upon removing the trim around the windshield, as well as inadvertantly part of the windshield (which is getting replaced anyway) we found two holes along the edge of the A-pillar.
As of tonight, all of the car is sanded except for the rocker panel ground effects, should be ready for paint tomorrow evening.
![](http://www.ls1camaro.net/freehosting/rightrear.jpg)
![](http://www.ls1camaro.net/freehosting/rightrear1.jpg)
![](http://www.ls1camaro.net/freehosting/nose.jpg)
![](http://www.ls1camaro.net/freehosting/windshield1.jpg)
![](http://www.ls1camaro.net/freehosting/windshield2.jpg)
![](http://www.ls1camaro.net/freehosting/windshield3.jpg)
![Big Grin](https://www.thirdgen.org/forums/images/smilies/biggrin.gif)
Originally posted by 1986CamaroSC
how do you get rust in texas?
Originally posted by 89V6FBIRD
They look like late 4thgen Firehawks to me... correct me if I'm wrong
Originally posted by megaracerx
black bird? its a camaro right?...lol....
but good luck with it
Hey, it sounded catchy at the moment
Besides, it sounds Air Force like
![Wink](https://www.thirdgen.org/forums/images/smilies/wink.gif)
1 Post
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
you taking the handles off? lock buttons, gfx emblmes at the least. if you paint around the handles it will most likley be the first place to start pealing.
Jeff
Jeff
the purple looks good..nice and sparkly...i would've did 2 big fat stripes instead of the ones you did that stop at the hood...personal taste tho...it looks like it turned out realy good...good job man..
Hotrodboba400
12-10-2019 07:07 PM
