I have an interrior question?
Car: 1990 350 tbi l98,
Engine: 5.7 tbi
Transmission: t5
Well this is not only my car that i have seen this happen too. But the problem is that every time it rains but i mean rains hard, Water seems to get into my passanger side floor mat. It seems to be comming from under the plastic of the body trim. Any one has experience this problem ,any way to fix?
I also wanted to now i have a 1990 camaro that has this little light , under the air conditioning in the middle of the dash . Right on top of the radio, it turns on when you turn on the head lights. Any use for it?
Car: 83 T-top T/A, 92 RS
Engine: 1970 LT1,305 TBI
Transmission: Th-400, 700r4
Axle/Gears: 3.42,2.73
The light is used to light up the radio & ashtray. as for the leak pull off the side trim and look for rust or the factory rubber patchs are missing.
Engine: 5.7 tbi
Transmission: t5
Well that little light doesnt do nothing. I have a picture there and it dosent even light that up a little bit. Can i change the bolb on that, to a stronger one?
Well i got the plastic peace and found that there was a peace of some type of rubber missing. I should that be my problem? What other problems could couse this?
