Replacing Power Window Switch
1 Post
Car: 1991 Chevy Camaro
Engine: 305 TBI
I ordered a new power window switch for my car. The only problem is that I don't really know how to properly remove the old one and install the new one. I tried a search but didn't find the info I was looking for. Any help would be appreciated.
Car: 91 Z28
Transmission: 4l60e
you have to take off the console plate or shift plate whatever its called and then pop the switch off the harness they are a paint to get off but with somecareful prying they come off and then you just plug the new one in. thats what i did when i replace mine cuz the platic around the edges were broken hope that info helps you
good luck with the install
1 Post
Engine: 305 TBI
OK, sounds easy enough. I have one more question though. I tried once before to take off my shifter plate but I couldn't because the shifter wouldn't come off. I took off the button and the spring but after that I don't know what to do. I think you are just supposed to pry up on it but I would like to get confirmation on this before I try it
. Thanks for the help so far.
![Frown](https://www.thirdgen.org/forums/images/smilies/frown.gif)
i just un screwed the two screws under the console lid (holding the plastic peice down) and just lifted up on that end (leave the shifter plate intact) just poped it off the harness and plugged in the new switch
Car: '86 IROC, '87 Volvo 240, '09 Malibu
Engine: LB9 5.0L
Once that clip's off, you can just pull the **** off.
1992 Trans Am
05-10-2023 07:19 PM
