fixing my pwr. antena
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: Trans Am "GTA"
The antena stoped working, so I took it apart and the plastic thing that pulls it down was broken.
Do you guys think that a GM kit to fix it is worth the money & time or should I just buy a new antena. t
The motor works because I can hear it every time I turn the car on or off. But Im woried that it might die as soon as I fix the other portion of the sistem.
& how do I know if the antena is an original, I dont want to buy a kit from GM and then find out that it dosnt fit the antena that I have.
I this post in the right place or should it be moved?
Car: 88 Iroc 91 Z28
Engine: 5.0 LB9
Transmission: WC T5 / 700R4
Axle/Gears: 10 bolt 3.73
I tryed to buy a complete power antanna from the dealer and thay told me it is no longer avalable.You can still buy the mast assembly i think that includes what you need.
Car: Trans Am "GTA"
What worries me is that I went throug the search and the only thing I found related to fixing the antena, was a guy that did this and right after the motor went down. So I dont want to spend the $45 and then have to buy a new antena.
Car: IROC Z
Engine: 5.7
my antenna is dead as well. the car had an aftermarket antenna on it so i didnt even know it had the power antenna until this year i pulled off the fender and it was chilling in there.
ill hhave to look at it and see if it was broken or what
please keep this thread going with info as how you fixed your antenna as im sure it will be use ful to me as well as others
