fiberglass/bondo headliner
Car: 1989 Mystery Firebird
Engine: 350 FIRST TPI
hey! Newbie here just like to let u guy know that im half way done with making my own fiberglass headliner.... right now im in the process of sanding ill update with pics as soon as im done.....
Car: American Iron Firebird
Engine: The little 305 that could.
Transmission: Richmond T-10
Axle/Gears: Floater 9" - 3.64 gears
Definately post pics when you're done. I hate headliner sag
Car: 85 camaro
Engine: 2.8 :(
Transmission: auto
Are you making it for a coupe or t-top car? My t-top headliner looks like...well, you know. I have been toying with the idea of glassing it for it's shape then recovering it. Let's see the pics either way.
Car: 91z28 and 88 SC thats for sale,in the sig
Engine: 305 TPI soon 383 stroker or 327
Transmission: t-5
i wanna see some pics,i may do it next also, im almost done doing my dash pad with some glass.
Transmission: t-5
maybe some people wanna DO THEIR OWN WORK.
this guy asked a simple question,nowhere in it did he ask for your opinion on if its worth it.
I made a simple observation, that's all. Geeze, are we a tad touchy today?
Nowhere did I ask for your 2 cents either, take your own advice.
The factory t-top liner is made of pressed fiberglass, which will loose it's shape when it is soaked with polyester resin (the extra weight of the resin deforms it) and is a major pain and mess to try to hold it where it is supposed to be as the resin cures. Not to mention that after cure it will be MUCH heavier than stock.
It would be much easier to get an ABS liner without covering and use it as a form to hand lay your own headliners from.
guys..guys lets all take a chill pill!! u guys make a go0d point! i started to do this cause after work i was bord... so thought lemme do this.. anyway its coming out great..... right now im spot glazing and should be done by the end of this week ...... im taking my time... ill try to take pics this week..... lataz
the 1 the only
--spade--
the 1 the only
--spade--
Car: 92 camaro rs
Engine: 305 tbi
Transmission: 7000r4
u know, as i was driving home today being annoyed by the tickle of a sagging headliner on my shaved head i was trying to think of something else i can do with that thing. that will be awesome when its done, I just might have try that myself
Car: '91 RS, 1994 Honda Accord LX
Engine: 3.1
Transmission: Automatic
I'm interested in what that would look like..I just recovered mine with new foam/cloth for $30 so i probably won't be messing with it again.
Car: 1985 Camaro, 1986 Trans Am
Engine: 5.0L carbed and 5.0L TPI
Transmission: TH700R4
Axle/Gears: 3.23 and 3.27 posi
I'd like to see pics as well. Wish I knew how to do fiberglass stuff.
Car: 87 Firebird Formula
Engine: 305 LG4
Here's a decent article...
http://www.hotrod.com/howto/60478/
Although that's overkill for the headliners. I'm guessing people are just cleaning up the stock piece, and putting 'glass over that.
There are websites about for "how to fiberglass". Just put that in your search and you should be able to figure it out.
formula00ra
Interior Parts Wanted
09-28-2015 11:50 AM
