Cruise Turn Signal Lever for Third Gen?
Car: 82 Pontiac Firebird s/e
Engine: 2.8 V6
Transmission: TH200C
I was looking on ebay for a Firebird Cruise Turn Signal Lever w/ delay for my 82 Firebird. The auctions specify for years 84 to 89 or for 90 to 92 but don't say anything about 82 to 84. The lever looks to be the same so I guess that it's the wiring harness or connector that's different. Does anyone know if the later model levers will fit the 82-84 cars and is there different wiring or connectors used.
Thanks.
Thanks.
Car: 1989 Iroc-Z
Engine: 5.7L TPI
The later years (90 - 92) will not work in the 82 - 89 models because the wire harness is shorter and connects inside the steering column. The 82 - 89 haness's connect at the base of the steering column.
Engine: 2.8 V6
Thanks Trickster, What about the connector at the end of the cable, is that the same on the 82-84 cars.
Thanks.
Thanks.
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
The wiring for the windshield wipers is different in the 82 and 83 vs. the 84-92 which most likely accounts for the discrepancy. The actual connector is the same, just the wiring differs.
Car: 1982 Trans Am
Engine: 350 Crate
Transmission: TH350
Just need a good wiring diagram and a multimeter.
