How do I mount switch in ashtray?
Car: 1989 Trans Am
Engine: l98
Transmission: 700 R4
Axle/Gears: 10 bolt with 3.23s
I am wiring up LED's in my 89 trans am. I have heard that you can mount a switch in the ashtray. How do you do this?
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1991 Camaro RS
Engine: 406ci
Transmission: T-56 LT1
I took the actual ashtray out and cut out a fited piece of plexiglass to fit in there, then cut out holes for 4 of my switches, need to still paint it to blend in
cheers
blake
cheers
blake
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
I took my ashtray out, cut a piece of aluminum out to fit perfectly, drilled all the necessary holes, epoxied it from the underside, and wired it up. As simple as that....and you can always use your imagination. This is my switch panel for my electronic exhaust cutout
1992 Trans Am
05-10-2023 07:19 PM
Street Lethal
04-30-2019 12:14 PM
