Those with 93+ rear seats
Did you just trim off the middle metal pieces that held the backrest in place?
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
You can leave the metal bar.. it doesn't interfere with the seat operation. It would be recommended to paint it to match the carpet however...
Engine: TPI 305/ v6
Originally posted by 25THRSS
I believe you can just hammer it out
Proper removal would require drilling all the spot welds so you can break it free with a drill bit for that purpose so you don't drill holes in/through the tunnel.
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
so whats the easiest way to do it? just cut or leave and paint it whatever my capet it? and also my back seats latches dont line up? what should i do?
Originally posted by deadbird
By experience... that does not work (which is why I was able to take a pic). The bar is pretty much solid and is intergral with a 'plate' that is spot welded to the trans/driveshaft tunnel in several spots. To 'just smack it out' will bend the hell out of the tunnel metal which, given enough beating will rip eventually.
Engine: TPI 305/ v6
Well.. I didn't mean it as there's no way in ____ you can do that but, I just know from randomly beating about mine, it didn't give an inch (except the tunnel at the weld points).
Car: 85 Camaro SC
Engine: V6
It would be best to just cut the prongs off with a sawzall or a die grinder. You would just have that little hump there but that could be blended out with some jute padding. Thats what I did with mine.
Car: 1988 Trans Am GTA Notchback
Engine: 305ci, 5.0L, TPI, HO
Transmission: Borg Warner T5 5-Speed
Axle/Gears: 9-Bolt Positraction Rear w/3.45 Grs
Originally posted by Dante93GTZ
Next time try a search; its been talked about a lot.
1992 Trans Am
05-10-2023 07:19 PM
