Dropped something down inte heater vent on dash
1 Post
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Its a non magnetic key, and I really need it.
Is there a "easy" way to reach it?
What things need to be removed to get a hand/tool into the air distributor?
/N.
/N.
1 Post
Car: 86 IROC
Engine: SC'ed 350
Axle/Gears: 4.11 12bolt
I did the same thing with a dash pad screw and thought it was gone until I replaced my stereo. Pulled out the old stereo and there it was, along with the strong magnet that stuck with a piece of broken string.
These vents must have holes in them, or at least mine does.
1 Post
Car: 1990 Firebird
Re: Dropped something down inte heater vent on dash
Quite an old thread, but doesn't resolve my current issue. What about a socket and extension (from removing my dash)? I tried a magnetic wand, but due to the size of the objects and curves it doesn't seem to be getting to it. Can you remove anything from the bottom, perhaps in back of the radio?
1 Post
Car: 88 (SOLD) & 90 Iroc convertibles
Engine: 5.0 TPI, 5.0 TPI
Transmission: 5 speed & auto
Axle/Gears: 3.08 & 2.73
Try this...........https://www.thirdgen.org/forums/inte...ter-vents.html
1 Post
Car: 1982 SC/1984 Z28
Engine: 305 4BBL/305 4BBL H.O.
Transmission: 700R4/700R4
Axle/Gears: 4th Gen 3.23 Posi/3.73 10 Bolt
Put a some panty hose over your shop vac's hose and stick it against the vent.
