guide coat
1 Post
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
guide coat
there is many question to guide coat. i have never seen a pic so here is one or three.
i am using the 3m powdered dry coat. you just rub it on and sand it off in an x pattern with a long block. it will show the low spots and high spots. the high spots show up first mental note them of sand em smooth at that point and then the lows are left for either filling or sanding the area around the low.
here is pic one of what the guide looks like. the black pad on the left is the top of the container it has the powder on it.
jeff
jeff
1 Post
Engine: 305 tpi LB9
there were no lows to show on that panel so here is some filler in progress that has lows you can see some lows along the top edge and one on the left where the area is dark after sanding. this image is a bit bigger to help see the guide left behind.
i like the 3m as there is no wait for a paint guide coat to dry this is wipe and sand no waiting. you can use just a watered down primer in your paint gun or rattle can primer or any paint and lightly dust the area. the key is it has to be a diffrent color. if you are using black primer this black powder is of no use to you.
Jeff
Jeff
Car: 85z28,
Yeah I posted about that stuff about3 months ago. It work great. U can even but it over your bondo before u prime and blocked out that way first.Car looks like its coming along good.I just started mine this weekend.
1 Post
Engine: 305 tpi LB9
its great on the bondo. i love it, paint sticks something wicked to the bondo.
jeff
jeff
1 Post
Engine: 305 tpi LB9
look at the pic of the bondo, you see areas where it is dark black, that is spots that the guide did not come off when sanding with the long blcok so those areas are low. if it high you hit it right away when blocking the primer wil be off and you'll get into the epoxy primer which is a diffrent color. or you can hit metal highs i have found while blocking without guide coat. guide coat helps with the low spots mostly.
also in the pic you can see two real shiney spots those are high spots that i have to tap still.
redformula88
10-14-2015 06:08 PM
