Suicide Dash?
Do you mean suicide DOORS?
If so, then it's when the doors open the opposite way.. IE: It would open from near the front window, and the hinge would be near the back...
They're called suicide doors because if they pop open or anything while driving, the wind will probably rip them off, and you'll possibly fly out
Car: 1989 Trans-Am
Engine: 305 TBI
Transmission: 700-R4
Ohh some kid said its called a suicide dash cause they decapitate people in an accident, I just wondered if that was true or not.
wtf? LOL. the dashes in these cars would crumple if it... atleast, that's what i think
I know old STEERING columns have bad raps because they won't collapse if you hit them... = Column flying through you
Car: 95 Z28
Transmission: Built 4L60E with 3000 Stall
Axle/Gears: 3.23? I'm not sure
ya i know 50s cars can be like that... do ours collapse? workin on mine doesnt seem like it does
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
look at where the bolts are for the column. the two the hold it up under the dash...
note that they're slots... if you slam into the column, it telescopes inward. if you hit it hard enough, it will break out of thoes thin pot alum blocks it bolts into and go inward more.
Car: 87 Trans am
Transmission: built 700R4
Axle/Gears: BW 9 bolt posi w/ disc
so instead of getting really hurt, you just get a lot of broken ribs? sounds good to me, but im not gonan go try it
Location: Doghouse ······································ Car: 1989 Formula 350 Vert Engine: 350 L98 Transmission: 700R4 Axle/Gears: B&W 3.27
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
The Colapsable steering column came into being in the 60's... My 67 was the first year for the current style where the tubes will fit into one another and colapse. Before that I think there was a little of movement but not much. Go way back into the 50's and the columns are fixed.
As for the Souicide dash??? I know way back when there was no seatbelts, there were some problems with a car with a glovebox coming open in an accident. Apparetly there were some accidents where children would slide forward in an accident and the glovebox would flop down, then when they would hit the box-door it took their head off.. They found some little kids heads in gloveboxes...
John
John
Car: 1992 Camaro RS AKA Big Nasty
Engine: Carbed '79 350 block, 360hp/380ftlbs (flywheel)
Transmission: 6speed from an unidentified 4th gen. ask me, ill tell you.
to go back to the meaning of suicide doors...
from my knowledge they were called that not because of them popping open and people flyin out ( look at jeeps for example). they were called suicide doors because when people would park their cars on the street, if they opened their door without looking another car could possibly run into the door and the door would kill the person instantly.
thats just when i always heard.
