2nd gen seats in a 3rd gen????
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 89' RS TPI,04' HEMI Dodge Q-cab
Engine: 383ci
Transmission: TCI 700R4, 3400 stall
Axle/Gears: 12 bolt 3.73
Anybody ever do this? If so, how hard/easy was it?
I know a lot of people put 4th gen seats in, but I have an extra pair of seats outta my 80' Camaro, and now that I blew MOST of my budget on the driveline, I am lookin for easy(aka CHEAP) mods!!!!!
backwards engineering, but it may work!!!
Car: '89 Camaro RS
Engine: LB8 V6 MFI
Transmission: T-5 5-speed
Axle/Gears: 3.42:1
I'm pretty sure 2nd Gen Camaro seats are a direct bolt in as long as you use the seat tracks from your 3rd Gen.
Last summer I found that a set of Z24 Cavalier seats are direct bolt-ins for my '70 Camaro, as long as I used the 2nd Gen Camaro seat tracks.
Now, ask me why I considered the Cavalier Z24 seats in my 2nd Gen Camaro ?? Because they 'recline'... and are WAY more comfortable than those awful 2nd Gen Camaro seats.
Actually, I have those Cavalier seats for sale now... due to the fact that a friend hooked me up w/ a set of '03 Dodge Viper seats for the '70.
Shoot me an email if you're interested in buying the Cavalier seats; you'll get a good deal on them.
BTW- There's not a rip or tear on these seats... NICE !!
![Big Grin](https://www.thirdgen.org/forums/images/smilies/biggrin.gif)
![Stick Out Tongue](https://www.thirdgen.org/forums/images/smilies/tongue.gif)
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
most GM seats will work if you use 3rdgen or 4thgen tracks.
personally i think you should goto a junkyard and see if you can find a nicer set then 2ndgen seats...
Originally posted by MrDude_1
...personally i think you should goto a junkyard and see if you can find a nicer set then 2ndgen seats...
Engine: 383ci
seats...
Well, not really lookin for "comfort" or "convience" here....if I was going to get new seats, the would be racing seats., and maybe a rollbar, but that just ain't in the budget right now!!
My drivers seat is torn, spring hangin out(rippin my shirts), and I think is is broke, cause it has a MAJOR lean-on!!
Thanks for the input , guys!!
Car: Camaro
Engine: 355c.i.
Transmission: th350
the seats in my 74lt kick ***, besides the fact that they dont recline
They are way comfy and supportive imo, and look hella better then most 3rd gen seats.
![Mad](https://www.thirdgen.org/forums/images/smilies/mad.gif)
1 Post
Car: 92 Z28
Axle/Gears: 3.73 10 bolt
From what I know the fronts should bolt right in, if not switch the tracks. The rears are supposedly too wide for thirdgens and I cant recall offhand if there buckets or not.
Engine: 383ci
seats
yep, the rear seat in the 80' is single bottoms with a 1 piece top.
I only plan on doin the fronts , though.
Car: 1989 Firebird
Engine: 2.8
the fronts will work just bolt your seattracks on the 2nd gen seat, and for the comment on reclining, your right they dont recline but are very comfortable, much more comfortable than my old 3rd gen seats, dont know how comfortable 4th gens are though.
Engine: 383ci
Well, the seats are in.
They bolted up with a lil grinding of the seat frame to clear the hinge of the adjustment arm, and drilling a new hole closer in for the actual mounting, but for the most part, straight forward.
Only took about two hours, too.
Engine: 383ci
another...not bad for only drillin 4 holes and a lil grinding...
I like the way they sit up a lil higher off the floor, too
Fast355
12-02-2016 06:33 PM
