Remove and Replace Stickers/Decals
Car: 86 IROC, 04 Ram, 05 SRT-4, 95 CBR
Engine: LB9, 5.7 Hemi, 2.4 turbo, 600cc
Transmission: 700-R4
Axle/Gears: 26 spline 3.42's for now
I just did this last week to my iroc. using a heat gun moderately will take the decals off no problem. the adhesive that is left behind is the bitch. i used a product called OOPS and a clean rag. soak a small spot on the rag and rub it onto the adhesive till you see it start to flake. take a plastic putty knife and just rub it away. you'll probably have to keep rubbing the adhesive remover on it, it just seems to come off better when it's wet. A friend of mine suggested 3M adhesive remover, but i had this sitting in the garage. I got a lot of compliments since i removed the decals, hope this helps.
Engine: 355
One other method is to use an eraser wheel purchased from an automotive paint store designed to remove stripes and decals along with the adhesive. It works very well with an electric drill motor and amazingly does harm most cured paints. Especially effective on old decals. Try it, you'll like the results. Dave
NBrehm
08-25-2015 11:49 PM
