ground effects removal help!!!
Car: 1987 Iroc
okay here is my situation. I bought 2 new solid firebird doors for my camaro. I know that the firebird ground effect on the door is different from the camaro ground effect. My question is how do I remove the ground effect from the firebird door??? Also, are gfx on the firebird and camaro doors mounted differently from each other???? Any help isgreatly appreciated!!!
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
remove the door panel and look towards the bottom of the door inside the framework, there should be several body nuts that will unscrew and your door skirt should just pop right out. There may be one or two more hidden nuts, it's been a while since I've had mine apart.
Car: 91 Camaro RS
Engine: TBI
Yea there is one on each end outside and i believe 4 on the inside of the door. REal easy to get to and take off. The longest part is taking the door panels off.
3rdgenparts
Exterior Parts for Sale
26
04-07-2016 11:21 AM
Thomas
10-03-2015 05:34 PM
92firebirdchris
08-14-2015 11:56 AM
