Doors are shaking while driving on the bad road
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1989 Firebird V6
Engine: 2.8
Transmission: auto
Hi,
Those doors on my car are shaking when I driving on the bad road, sounds like they are no assembled well or closed well but they did, is that caused by the saggy door?? both of they are hard to open......
How should I check?
Joe
How should I check?
Joe
Car: 89 Firebird Formula(Totalled), 91 C
Engine: Mild 350
Axle/Gears: 2.73 :-(
That was happening to me also a while back. Hit any bump in the road and the door clang, sounds like the car is falling apart. Check the door latches. Mine were worn out and had play where they latch to the door striker. Replaced them and doors have been perfect ever since.
Engine: 2.8
Transmission: auto
thank you, my English is not good, is "latch" the sticking out material which locked with the door?
Car: 91 Camaro RS
Engine: 3.1L V-6
Transmission: Fresh 700R4
"striker" is the portion sticking out of the door frame
the "latch" is the part that contacts the striker and is on the door itself
good luck joe
good luck joe
