Can i mount gfx without the brackets that come stock on cars with them?
Car: 1986 Camaro SC
i'm talking about the rocker and door pieces
say if i put them in place and drilled the holes in the right locations, would i be able to make it work?
Car: 85 Trans Am WS6
Engine: 305HO L69
from what i've heard, your gfx with sag. if you have a little metal working skill, you could probably fab up a brag pretty easily with a little sheet metal
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
:werd:
I had one on my driver door which rotted, and it sags considerably. The pieces can be found relatively inexpensively at a wrecking yard, or through YearOne. I haven't looked at GM's goodmark brand for these pieces, but as mentioned, you can fabricate something fairly easily.
Re: Can i mount gfx without the brackets that come stock on cars with them?
1992 Trans Am
05-10-2023 07:19 PM
Terrell351
06-13-2021 01:13 PM
