Dash Tachometer
Car: 1990 Camaro RS with T-Tops
Engine: 312 TBI(305) 0.040 over
Transmission: out of a v-6 s-10 blazer!
Dash Tachometer
My stock tach is peged over past 8000 rpm. I have only had it running for a couple min but the tach didnt move. My question is is the cluster messed up or is it just not hooked up right?
i am sure the wire is hooked up! but still no change! i unpluged the cluster and it came back to 0 put the cluster back in started the car and pegged the tach again. Any ideas?
I saw the test you posted for someone else might try that soon!?
unless you think cluster is bad
Thanks for you help!
ivon
ivon
