Interior Stinks
Car: 1989 Camaro IROC-Z
Engine: L98 350 TPI
Transmission: Built TH-700 R4 (Vilgilante 2800)
Axle/Gears: 9 bolt w/ PBR's
Interior Stinks
Well I did the smart thing of leaving my windows open over night and you guessed it, it rained. Now my car stinks. What can I do /use to get rid of the stink? Thanks
Kevin
Kevin
Car: 1983 Trans Am
Engine: N/A
Transmission: N/A
febreeze works well.
I would just wait for a sunny day and open everything and let your car sit and air dry.
At the very worst you will need to pull the carpet and replace your insulating foam. I reccomend this regardless.
I put window flashing down, and it not only made the car smell better, but ride inside was far quieter.
Car: 1992
Engine: 350TPI
Spray everything!! down with upholsety cleaner and set it soak. Then steam clean and almost any smell will leave. Just make sure to let it dry in the sun. I find that when my girlfriend pukes BK Whoppers it gets that nasty Mayo stink out.
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
Car: 1983 Trans Am
Engine: N/A
Transmission: N/A
I didnt weigh it. I am gonna guess it was probably close to 6 or 7 pounds. Because I hold an entire 4'x25'' roll between my thumb and pointer finger.
Not quite exact, but a close estimate.
It is basically bubble wrap with aluminum foil on either side, so it might look heavy. But it is really freaking light.
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
hey Midnight Sun,
they don't have any mountain dew up in washington?
coke isn't bad, that's all we serve at work,i prefer vanilla coke though.
btw, you can get that window flashing at a place like home depot or lowes correct?
1 Post
Car: Camaro
Engine: 3800
Pretty light stuff.
-Bud
Car: 1988 Iroc-Z
While we are in the "Interior stinks" subject, how do you get rid of the smell of paint from a roll cage?
suprised no one said hang a tree from your mirror.......
Engine: L98 350 TPI
LOL I all ready have a 'tree" hanging from the mirror.
Kevin
Kevin
1Aauto
Sponsored Vendors
24
03-27-2018 11:59 AM
