T top repair question
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: Green 1991 Firebird Formula
I see a lot of t-tops for sale with some outer trim piece falling off as shown in the attached picture. Does anybody know what part that is and if it can be replaced?
From a broken top that I took apart, I know that there is a rubber seal that screws to the part of the top that is glued to the glass but it doesn't look like that seal can fall apart like the one in the picture.
Any help would be appreciated as I am trying to acquire an extra pair that is in good condition or easily fixed. From what I have found, the t-top parts either come off easily with a few screws or are attached with some kind of glue and are almost impossible to take off
Any help would be appreciated. Thanks
Car: 86 z28
Engine: 305 carbed with 3" Y pipe back
Transmission: 700r4 that is breaking down
yes that peice of rubber can be replaced it comes with the seal kit you get from GM i am sure.
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Anyone know if you can get just thes pieces, and if so, where? I replaced my T-top seals and T-bar (mine blew off going down the road!) last summer and these were not in the kit. I'd like to finish up my seals and do this part too.....
Have a Great Day!!!
- Vern
Have a Great Day!!!
- Vern
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
You can find the pieces-parts numbers in my sig. The rubber piece that commonly pulls off the glass is the awning and has been upgraded to a plastic piece.
Instructins for replacement can be found here.
IROCZDAVE (88-L98)
10-06-2016 09:08 AM
