Stupid Q, cant get hood open =(
Car: 1989 Iroc-Z Camaro
Engine: 5.7 liter 350
ok, im an idiot, and cant get my hood to open, 89 irocz camaro....I used to be able to use hood release and it would pop up a little then i could grab it where headlights are and pull up a bit, then get the center latch....now, It barely lifts at all when I hit hood release, then wont go any higher, I've tried pushing really hard all over center/center sides of hood, maybe I'm hitting wrong spots?
Any help GREATLY appreciated...I really need to get the hood up before I can do much..
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
We just covered this on gen tech. Search will bring it up. Pop the hood in the corner near the driver's door, about where the back of the hinge is, or right above the latch. Hood should pop up. See the other thread for more info.
Car: 84z, 65 elcamino
Engine: l69 and a hyped up sbc in the camino
Transmission: t5 m21
Axle/Gears: 373s 411s
hit it and it will open with an open palm or the back edges push foward. once its open replace the spring
![Wink](https://www.thirdgen.org/forums/images/smilies/wink.gif)
Car: 89 RS
Engine: 305 TBI
Have you tried slamming the passenger door?
Seriously, it works. Pull the hood release, get out, walk around, and open and shut the passenger door. I read about that on here and was like "What?? No way..." until I tried it.
And rather than replace the spring, try WD-40'ing the hell out of it first. That's what I did, and it's worked fine since then. If that doens't work, then start replacing stuff.
~Chris
~Chris
Hotrodboba400
12-10-2019 07:07 PM
