Door Panels Worth The Price
Car: 1991 Formula
Transmission: 5 speed
I found a set of molded door panels in an '87 Formula today in a junkyard for $50.00 for everything.They're in pretty good shape other than the cloth inserts. I was going to dye them black & have the cloth replaced. Do these panels sound like it's worth it? Thanks Chris
Car: 2008.5 Mazdaspeed 3 GT
Engine: 2.3 DISI Turbo
Transmission: 6 speed MT
If the cloth needs to be replaced it doesn't sound like they would have been worth 50 smackers... to me anyway. With that amount already invested, I would seriously consider buying another set of panels in good shape from a better salvage yard. Most people couldn't replace the cloth insert correctly if their life depended on it, let alone adding the price of the new cloth into the total. It's up to you to judge your own skills there, then post pics so we can pick on you. [joke]
Car: 1992 Jade Green---Trans Am Converti
If by 'molded' you mean the upper level plastic door panels then that's a pretty good deal. Replacing the cloth in them doesn't seem like it would be as hard as the regular panels.. You did make sure to the get metal brackets that are on the door right?
Kevin D.
Kevin D.
Car: 1991 Formula
I have'nt bought them yet, I was just wondering if they would be worth the price. Those are the first set I've seen in a yard. I might put them in my '91 if they would look O.K. Chris
Car: 1990 Trans Am
Engine: Lb9
Transmission: factory T5
Axle/Gears: 3.08 limited slip
to ease the replacement of the cloth just use a border of some sort around the seem of the cloth to the vinyl so you dont have to make it a perfect fix, shouldnt be hard. If the cardbord backing is in good shape id say go for it. And DO NOT FORGET the backet that attaches it to the door (its riveted in) because its way different from yours.
Deos that include armrests and the part where the inside handle goes?
Car: 1990 Formula
Axle/Gears: 3:73 Posi
Taht's more than we'd charge at the yard i work at but whatever. if they are in good shape other than the cloth and it includes everything (armrests, door handle trim AND the mounting piece) i'd say go for it and recovering the cloth insert isn't that hard i re did my entire door panels.
1 Post
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
I got the same panels you're looking at for $30 at a yard including everything. I also plan on dying them black and replacing the cloth section (which does look like a pain in the *** and isn't close to as easy as doing the same thing on a stock panel!). The rivits are a pain, but with a cordless drill and some time you'll get them out. They're made of aluminum so you can drill them out. I had a fairly weak drill so it took me a while to remove the 4 rivits from each door. Here are the panels I got
GTA Door Panels
GTA Door Panels
1992 Trans Am
05-10-2023 07:19 PM
IROCZDAVE (88-L98)
10-06-2016 09:08 AM
IROCZDAVE (88-L98)
08-06-2015 03:51 PM
