Ecm mount???
Car: 90' TA GTA
Ecm mount???
Does anyone now how the ECm mount uder the dash i bought my car about a year ago and it was just laying on the panel underneath it.
Also how do you keep the panel that says "performace Suspision" on i have some tall friend and they keep knocing it off. and i dont want to use super Glue
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
There's a large plastic bracket that holds the ECM tucked neatly behind the dash on that side. Go to a junkyard and find one, they probably have a lot of them.
The lower dash panels should have screws holding them together, and if they don't, someone probably stripped out the screw holes and just threw the screws out leaving the tabs to hold the panels in place. Get some larger sheet metal screws and screw it on the way its supposed to be. Should be 3 holes, and if there are more empty holes in the metal bracket, you need more screws for other panels. The ECM bracket mounts to two nylon parts that are in this same area, and there is a pin at the top that mounts into a hole at the top of the dash. Might be slightly easier if you remove the dash pad when you mount the ECM bracket so you can guide it into the upper mounting hole.
IROCZDAVE (88-L98)
09-02-2015 08:49 AM
IROCZDAVE (88-L98)
09-02-2015 08:43 AM
