Installing my Tints.....
Car: 1990 350 tbi l98,
Engine: 5.7 tbi
Transmission: t5
My buddy give me a roll of tint and wanted to now what do i need to put them on?? like a blaid , etc...
-Eric
-Eric
We're not trying to dissuade you from trying things on your own, but trust us, tinting is a job best left to professionals. You usually can get a warranty with it, also, which is the best part, IMO.
Whatever you do, do NOT clean them with Windex!
Car: '86 Trans Am
Engine: LG4
Axle/Gears: 3.70 Posi disc 9 bolt
I've done my own plenty of times. I have to scrape it each time I get a ticket for it being too dark, so might as well learn how to put it on also.
Just remember that there is a clear sheet attached to the film and it has to be removed prior to placing the side on the window.
If you put it on the window with the clear sheet attached it will bubble like crazy in a few days or so.
Take your door panels off when doing this so that you can take the film down an inch or so below the rubber liner at the top of the inside door panel.
Windows are easy. The hatch is another story.
Jim.
Jim.
Car: 1990 Pontiac Firebird
Engine: 3.1L v6
Transmission: Automatic
can a hatch with defrost even be tinted? can you still use the defroster? i think you would end up with little gaps around each of the defroster grids.
Car: '86 Trans Am
Engine: LG4
Small bubbles, but they are very tiny and you can live with it. I think you can use your defroster after a month or so, but too sure. Check with a local tint shop.
Jim.
Jim.
Car: 86 z28
Engine: 305 carbed with 3" Y pipe back
Transmission: 700r4 that is breaking down
i don't got no little bubles around mine and they work find altho i might just get rid of em cause my car is never going to see a winter in its life
gixxer92
09-01-2015 04:32 PM
