aftermarket steering wheels
Car: 90 Firebird
Engine: 305 tbi
I'm wanting to replace my old worn air-bag steering wheel for something new and cool.
are there any brands that are prefered over others here?
I look at Grant wheels and it looks like there is no install kit for my make and year... because I have a bag? I'm sure other people must have been thru this?
any pics of your interior or steering wheel would be cool too
1 Post
Car: Z28
You aren't finding an install kit for your year car I think because it's illegal to remove the air bag. An install kit from a 89 should work fine.
Here's my Grant Le Mans steering wheel.
Car: 90 Firebird
Engine: 305 tbi
thanks for the info, I was thinking it was legal for the bag to be taken out, considering how some of these bags go haywire and cause burns and cuts, etc... I've always felt uncomfortable about it.
now my steering wheel is in very bad shape, the vinyl rotting off it... I would think it should be legal...
these wheels look a lot better installed, I look at all the different ones and sometimes can't imagine it looking good... but that looks great 3gc.
1 Post
Car: Z28
Thanks. I wasn't saying you shouldn't remove it and replace it. I would remove it but keep the bag and wheel and if you ever want to sell the car, put it back on.
Car: 1987 Pontiac Trans Am GTA, 1992 Chevrolet Camaro RS
Engine: Custom 350, 3.1 V6
Transmission: 700R4, 700R4
I've wanted to replace the steering wheel in my 92 with an aftermarket one, but I've heard stories that the insurance company can deny to pay your claim if you are in accident and have removed the factory air bag. Is there any truth to this?
Car: 1990 Iroc-Z
I aslo have the airbag on mine and it looks horrible. How exactly do you remove the stock airbag steering wheel? is it a PITA because of the bag, or is it just like any other steering wheel removal?
Car: 90 Firebird
Engine: 305 tbi
Car: 92 Camaro RS
i've also heard this, but i only pay liability anyways, so no matter what if i wreck it, im screwed, what i think most do is just keep the stock one, and if u get in a wreck, switch em out and no one will know. jsut hope the wreck wasnt bad enough that the air bag (if there) should have deployed.. good luck
Car: 1984 Pontiac Trans Am WS6
Engine: H.O. 305 5.0L;L69
Transmission: T-5; Axle Ratio 3.73
Those look good, but I just say stay with the stock one. I think they look great, but thats my opinion
I'd really like to do this, I put a Grant wheel in the Trans Am, but I'm worried about the airbag issue with the Camaro.
Car: 88 Trans Am
Engine: 5.7 TPI
Here's mine. It's a grant. (red shift plate is now black once again!!!!)
I really like mine,....but I think I'm going to convert back to the stock radio controlled wheel once I find one in a condition I like.
Car: 90 Firebird
Engine: 305 tbi
Car: '89 Firebird Formula
Engine: 305 TBI
i believe i have the same one pecha does, cept the mounting bolts go flush with the wheel, and are black.. its only like 13" or something, i wouldnt want to go back to a larger wheel
part #710 on grant's site.. very fun to drive with
1 Post
Car: 89 iroc
Engine: 355 TPI FINALLY
Transmission: 700r4/ SHIFT KIT
do we need an adapter to make these work. I just bought a APC which uses the same install kit.....really confused help.....and if we do where do you get one... I'm going back to the store later today?? who knows maybe they'll know what I'm talking about.
yes you need an adapter for all aftermarkets, to my knowledge anyways, to adjust from the stock setup. the stock wheels have the plastic and metal piece attached to the wheel that gives the space between the blinkers to the wheel itself. all the adapter does is replace that gap and allow the aftermarket piece to be bolted directly to the adapter.
1 Post
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
Mine has a gay r*cer wheel that came with it. It's a MoMo.
1 Post
Car: 89 iroc
just finished getting the wheel on straight, pretty simple once you have all the right parts
1 Post
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Is it just me or am I the only one who finds the stock steering wheel better than almost all these aftermarket wheels. None of them toot my whistle =/.
Car: 89 Camaro RS
Engine: sbc 400
Transmission: th350
as much as i hate apc (oh, and i do. with a passion), i believe grant makes their steering wheel stuff. the install kits are identical (i have both), the wheels are the same design, and i know the install kits are now labeled as APC by Grant. i'm planning on getting one of the 3-spoke types and just doing a couple of rattle can coats on the center button to cover the APC logo. i've got the cheap 4-spoke grant one in now (the same as a few others here) and its deffinately beat.
Car: 91 firebird now
Transmission: 5 speed
If you do convert to a regular wheel without an air bag and you have one how do you keep the infl rest light from coming on? Do you just twist the wires together?
Car: 1991 Firebird Formula
Engine: L03 305 TBI
Transmission: 700-R4
Originally posted by PorscheNoSub
i realize this is an old post, but i cant seem to find an answer to the INF REST light problem when removing the air bag. is there any other way to keep the light from staying on without removing the bulb? i would rather not tear into the dash if i didnt have to.
Oh and here is a pic of the wheel I put in after I removed the rotted out air back wheel. 12 bucks from the junk yard
Car: 1990 Formula
Axle/Gears: 3:73 Posi
When i removed my airbag wheel (see pic above) and replaced it with a 87 Firebird 3 spoke wheel. i removed the infl rest fuse and the bulb in the cluster. no light for me !
