Removing headlight knob
Car: 1987 Pontiac Trans Am GTA, 1992 Chevrolet Camaro RS
Engine: Custom 350, 3.1 V6
Transmission: 700R4, 700R4
Removing headlight ****
I had the night off from work tonight, so I decided it would be a good time to swap out the burnt out gauges lights I have. Well I was able to get most of the das apart, but I couldn't get the trim panel around the bezel off because the headlight ****. How do you removed this?
1 Post
Car: Camaro
Engine: 3800
Dunno if 91-92 cars are different... but on mine there is a clip on the back that you gotta push with a straight slot scewdriver. Kinda similar to a cable speedo clip in a way. Same idea to get it off. Hope that helps a bit
-Bud
-Bud
Car: 1984 Z28
Engine: 5.7
Transmission: Auto w/ shift kit
what he said ^^^^
i was at a junkyard and needed the peice behind it and i was prying pulling twisting till the metal snapped 20 mins later and then i was like how am i gonna get this on mine and i noticed the little thing u push when it was off
Car: GM & Jaguar
Engine: Various
Transmission: Various
Axle/Gears: Various
Mine had a little obnoxious button like the old school headlight dimmers. If you can with a flashlight look for a small button, if you see one underneath the dimmer switch depress with the **** all the way out, then extract it... what a pain.
Car: 91RS
Engine: 305tbi
The only problem I had was once its out, the headlights are on.
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
in order to do it and not have the headlights on your gonna need to disconect the battery too..ive done that before myself ..LOL but it shouldnt be too dificult just take your time and take a break when needed
Car: 91RS
Engine: 305tbi
Thanks guys, I will attemp this again when I am off Monday. Also, I was reading that you need some sort of connector for the 194 bulbs because the factory ones are soldered on. I asked one of the guys working at Autozone if they carried them, and he didn't seem to have a clue what I was talking about. What is the name of the connector, or part number?
Originally posted by PyRo9862
Couldn't you just pull the fuse? I just put the **** back in once the trim piece was off.
Does anyone know the name of socket for the bulb?
IROCZDAVE (88-L98)
09-02-2015 08:43 AM
