Tweaked my door...
Tweaked my door...
Well, to make a long story short, I did something stupid in lowering my car from a lift without checking whether my doors were open or closed... needless to say, when the car came down and the open door met with a floor-standing tire changer and I heard a loud "CRACK!" my heart sank. The door needs re-alignment and I need a replacement Ground effect moulding on the driver's side.
Any recommendations or parts that I could get from you guys?
Car: GM & Jaguar
Engine: Various
Transmission: Various
Axle/Gears: Various
It really depends on how bad it's tweaked. You may be able to get away with replacing the hinge (if it may unbolt from the door - not sure now). Either the hinge is bent, the material where the hinge is bent, or the whole door is tweaked - it ought to be fixable, but the door most likely needs to come off.
I think I just bent the hinge, because it now squeaks heavily when I move the door. Thing is, when I look in there to see where it bent there's no paint missing, wierd huh? I was thinking I should just take it to a body shop and get it done, or do you think its something I can do myself with a friend helpin' out?
Looking at it in my Chiltons it doesnt seem that bad, but being new to F-Body there are probably some tricks I dont know about for it...
