Cracked rubber wing can it be fixed?????
Car: 1987 IROC-Z
Engine: 305 LB9
Transmission: 5 Speed
Axle/Gears: 3.70 Posi BW 9 Bolt
My rubber wing is cracked and i want to fix it so i can have my car painted. Now i dont have the money to get a fiberglass one so thats out of the question but i know theres a right way that i can fix my spoiler so it looks decent im not lookin for great but just so its one shape. so how do i go about fixing it??
Car: 1987 Camaro Z28 IROC-Z
Engine: 5.7L TPI
Axle/Gears: 3.42:1
The short form is NO. There is NO repair for a cracked up stock aerowing spoiler. Take it off the car, and find the nearest dumpster.
The cracking is due to the metal frame of the spoiler rusting up so bad it distorts the shape of the rubber molded around it, eventually causing it to split. Once it has split, deterioration increases in speed as water will get in there no matter how much goo you shove in it. It originally starts due to the attaching pegs on the sides of the rear glass. There are three of them which are three holes per side that let water in with no where to go. Instant rust for the spoiler frame. The way the car is shaped as you drive in the rain the water is forced into the spoiler, only making a bad design worse.
Car: 1986 Trans Am
Engine: 305 LB9 TPI
Transmission: 700-R4
yup, i filled mine with bondo and then painted it. Still looks good, and if you texture it right then it will stock. I had a guide somewhere on it. lemme find it......
here it is
https://www.thirdgen.org/techbb2/sho...hreadid=208771
Shane
here it is
Shane
Engine: 5.7L TPI
Axle/Gears: 3.42:1
here it is
Shane
here it is
Shane
IROCZDAVE (88-L98)
Exterior Parts for Sale
09-06-2015 06:23 AM
IROCZDAVE (88-L98)
09-02-2015 08:49 AM
