Cuttin a hole in my hood
Car: 89 Camaro RS
Engine: 350 carbed now
Transmission: World Class T5
Axle/Gears: Peg Leg w/ 3.73's
Well guys I just got my new engine in my car last weekend and I was lookin at my performer RPM intake and of course I noticed that there was going to be hood clearence problems with my air cleaner. So I have been thinking about it and I think I want to fab up a shaker air cleaner assembley and cut a whole in my hood kinda like the mach I's I already have ideas on the scoop and now I am wondering what tool you guys think I should use to cut the hole in my hood. I appreciatte the help.
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
A saber/jig saw will work just fine. Use around a 22tpi blade since the metal is such a light gauge and let the blade do the cutting, don't force it.
Car: 89 Camaro RS
See I have a jig saw but I wasnt thinking it would cut through my hood, that thing is pretty thick. I'll give it a try. Thanks.
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
I'd just use a die grinder. I used that to install my fender louvers....it cut through the fenders with no problem. It also didn't distort the metal around it either...
Car: 92 caddy PIMP
Engine: 4.8
Transmission: i dunno
That sounds awesome be sure to send pics when your done. Id like to see a 3rd gen with a mach1 ram shaker setup.
Nate
Nate
Car: 89 Camaro RS
Oh and i will defenetly post pics once I get it in. I just need to get everything together and get it done. I also havent got the car running yet because I need to buy the rest of the fuel system so I wont be cutting anything until I get that taken car of. Thanks for your input guys.
1 Post
Car: 91Z
Engine: 355/afr/sr/lpe219
Transmission: built 700R
Just a thought here, but would a regular RS hood not be a better starting point?? That way the blisters/louvers, would not be an issue. I am just throughing out an idea. Ohh, and a jig saw may work, but I would prob. use a die grinder myself.
Engine: 5.7
how many RPMs does your die grinder operate at? I was thinkin about doing it that way, but I want to do it as easy and clean as possible and it would probably take a while longer with a die grinder because the hole is going to be pretty big.
I'm not sure how many RPMS it runs at. If you decide to use a die grinder....it will take a bit longer...but you will get great results with it. Like I said...it won't distort the metal like a Jig Saw could possibly do. It would be better to take it awhile longer to cut it out...and turn out nice...rather than to cut it out faster....and have something bad happen.....just watchin a brotha's back..haha, good luck man, definently post pictures when you start this project!
Car: 89 Camaro RS
Alright then, die grinder it is. Like I said I dont know exactly when I am going to get started on this thing but it shouldnt be very long. I need to get a digital camera so I can take pics of the whole process for you guys. I appreciatte the input guys and I will post up as soon as I get started.
Hotrodboba400
12-10-2019 07:07 PM
