estimate on damage....
Moderator/TGO Supporter
Car: 1997 Z28
I would think somewhere around 1200-1500.
I had similar damage to my car, and it was around that.
Granted, that was at the dealership, a local body shop could do that for less.
Or if you really wanna save some money, go find a fender, mount it, clean the bumper up. And then take it to see how much it would be to just get sprayed.
- 89_IROC
Car: 91RS
Engine: 305tbi
If you replace the fender, and do some of the prep work it would probably run $500. Unless you get really lucky and fender and bumper that match the color.
1 Post
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Is there a crease in the dent? If not, you might be able to push it out from the other side with your hand.
I did that once. I leaned on the fender on my Z28, and my knee pushed a spot in right around were your dent it. Only it didn't pop back out. I just moved the battery, gave it a little push, and it popped right out.
if this happened to me I would not spend more than 700 to fix.
I would figure the shop would need to:
remove/replace rt fender 125 used part($40 for some folks) + 4.3 hrs to install/paint
3 hrs to repair front bumper cover and 2.4 hrs to paint
1 hr to remove/install bumper cover
remove/replace side marker lamp $12.00 part + .2 hrs
paint/materials 150
= roughly $700.00 depending on labor rates and what repair times you negotiate with the repair shop
Hope this helps
9d1burd had a dealership shop write his estimate which would be higher than some of your mom and pop shops.
paint/materials 150
Hope this helps
Car: 87 IROC Z28
Engine: Custom Forged 355
Axle/Gears: 9" 4:11's Detroit Locker
i would charge you about 200 to fix that, it takes about maybe 2 hours tops from begining to paint.
its only a fender adn a little peice on the nose that needs actual work, the rest of the nose and fender just gets sanded down and painted....
Car: 91RS
Engine: 305tbi
Thats it? Perhaps I should go to wherever you work and get an estimate. I have a dent in the same spot, one on each fender only much smaller, and no damage to the nose. I was quoted $300 each by another shop.
Car: 1986 Pontiac Trans Am
Engine: LG4 305
