Black tar under carpets?
so im swapping out my interior from tan to black. have the whole thing out and welded my roll cage in and i'm noticing there is like a black tarish substance under the carpets. its also on the plastic sheets that cover the factory sound deadening underlays. i know this stuff is factory. while welding the roll cage in, it was smeared all over the floor pans. im wondering, what is the best substance to clean this gunk out with? i want to get it all removed so i can lay down the new carpets and sound deadener.
it was also under the deadener behind the front kick panels
Car: 1989 Iroc-Z
Engine: 5.7L TPI
I scraped the biggest part of it off with a putty knife and used a citrus based adhesive remover to clean the residue off. Needless to say that for awhile, everything smelled and tasted like oranges after that.
because its in spots the factory didnt put it. it was hot out and it got stuck on my boot and i tracked it around the car. i need to get it off the floor pans so i can lay down some dynomat before laying down my new carpets.
