91-92 camaro GFX part numbers
Old 04-09-2004 | 10:18 PM
25THRSS's Avatar
What are they? So far I have only come up with the front spoiler, which is 16514355. Does anyone know the rocker panel part numbers, etc?
Old 04-09-2004 | 10:50 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
(check sig)
Old 04-09-2004 | 10:58 PM
25THRSS's Avatar
Wow, thanks man! I thought I had hit the jackpot, but a bunch of the pages are cut off and I can't get the info I need. Do you happen to have the rest of the cut off pages?
Old 04-09-2004 | 11:13 PM
deadbird's Avatar
Engine: TPI 305/ v6
They should (and I say that loosely) be there. Unfortunately, I designed the pages with notepad and tested in IE5+. The part number listings should scroll with the diagram drawing staying fixed.
It works modestly in Opera but, I have no clue about Netscape or other browsers.
If you still have problems, shoot me an email and I will send you the seperate .gif images. Sorry for the problems.
Old 04-09-2004 | 11:15 PM
25THRSS's Avatar
It's not working for me, but don't be sorry. You are doing me a huge favor and I really appreciate it. Nothing to be sorry about man. I owe you one. :hail:
Old 04-11-2004 | 01:58 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I just tested it in FireFox and the page won't scroll down.
I see the "Close Window" button and the top of a text input dialog window, and that is it at the bottom.
Old 04-13-2004 | 02:11 AM
Vaneat-91RS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: A/T
Re: 91-92 camaro GFX part numbers
I should be able to get them for you tomorrow at work (I'm a GM counterman). Check back late tomorrow (I'm pacific time zone).
***writing note to self***
Old 04-13-2004 | 11:43 PM
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: A/T
Re: Re: 91-92 camaro GFX part numbers
Okay, here is the list:
RH rocker..................................................12510810
LH rocker..................................................12510811
LH Qtr.......................................................88891635
RH Qtr.......................................................88891634
Frt Ext (bottom of frt fascia).....................16514355
RH Door Mldg............................................12503272
LH Door Mldg............................................12503273
And in case you need them:
Frt Fascia..................................................16503496
RR Fascia..................................................10118409
Old 04-14-2004 | 07:54 AM
25THRSS's Avatar
Vaneat-91RS rocks! :hail:
Old 04-14-2004 | 09:29 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
www.gmpartsdirect.com prices
Attached Thumbnails 91-92 camaro GFX part numbers-91-92-camaro-ground
Old 04-14-2004 | 10:15 AM
25THRSS's Avatar
All I need is the front spoiler and both rocker panel ground effects. Which ones are those?
Old 04-16-2004 | 10:36 AM
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: A/T
RH rocker (effect).....................................12510810
Frt Ext (bottom of frt fascia)--spoiler).......16514355
You actually need all of these parts. If you don't put on the lower door moldings, the car won't look right, as they are really a part of the rocker panel g/fx. same with the quarter moldings. Take a trip to your local wrecking yard and take a look at one and you'll see what I mean.
Old 04-16-2004 | 01:52 PM
25THRSS's Avatar
My car is a 92 so I already have everything. Unfortunately my front spoiler and both rocker panel gfx are cracked and scraped up and I want to purchase new ones before it goes in for paint. That's why I only need the 3 mentioned above.
Old 04-16-2004 | 10:24 PM
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: A/T
Got it. Then you only need these pieces:
Old 04-16-2004 | 10:26 PM
25THRSS's Avatar
Vaneat you have helped me out a bunch. I really appreciate it a lot! Thanks to everyone for the help!
Frozer!!!
01-19-2024 05:55 PM
1992 Trans Am
05-10-2023 08:19 PM
twest2k2
08-24-2015 12:26 PM
Cheibu70
Interior Parts Wanted
08-15-2015 01:11 PM
armybyrd
08-10-2015 10:23 PM
