How should i remove this rust?
Car: 1986 Trans Am
Engine: 305 LB9 TPI
Transmission: 700-R4
Took out my interior and foudn rust, but very small amount. I just wannt get rid of it so i dont gotta worry about it later. I do have aresol primer and aresol Platinum Paint. What shoudl i do to make sure itnever some back?
Heres the rest of the interior, pretty much rust free..
Car: 1986 Trans Am
Engine: 305 LB9 TPI
d00d shush about the fur.....
I need help here. NAd for the life of me i cant get that fn bolt out. So no go there....
Shane
Shane
Car: 85 firebird
Engine: Pos 2.8 pulled and replaced with a 350 tpi motor converted to carb.
Transmission: 700r4, vette servo,shift kit, hayden 15"x8" trans cooler.
Spray the bolt real good with pb blaster and let it sit overnite.
Car: 1986 Trans Am
Engine: 305 LB9 TPI
ok, i got some of that stuff, its got a blue cap, its in the storage shed outside. We used it in our electric clipper when we were replacing a ruisted shut blade.
What about the other rust. Should i just sand itdoewn primer it and then paint it?
1 Post
Car: 1983 Trans Am
Engine: 305 LG4
yeah its that simple
I had something similar to that except worse, I just sanded it down(didnt primer it) and bought white rust-proof paint at walmart and its held up pretty good. I think it looks good too, not that it matters nobody will ever see it but yah
Car: 1986 Trans Am
Engine: 305 LB9 TPI
only rust proof paint i got is black rustoleum. But i think i'd rather get somethning that matches the already there color. But i dunno. I might need the little primer i got left.
Shane
Shane
1 Post
Car: 83 Z28
Engine: 305 (LG4)
Transmission: THM700R4
Axle/Gears: 10 bolt, 3.23 non-LS
It would be a good idea to take a look underneath the car as well. Some of those joints may be rusting from the underside.
phil
phil
Car: 1990 TA
Engine: LB9 305
Transmission: 4L60
Hotrodboba400
12-10-2019 07:07 PM
