Floor mat care....
Car: 1986 Trans Am
Engine: 305 LB9 TPI
Transmission: 700-R4
Floor mat care....
Alright guys, i have decided today to clean my stock floor mats with every bit of skill i got. I found one thing that works very well with them,
Step 1-Get a pressure washer, in the cleaning chemical tank, put tide or any cloth washing soap.
Step 2-Spray the cleaning solution on the floor mats and let sit one minute. Use full pressure(i used 1200psi) and blast it clean.
At this stage it will be mostly clean, but one more time would do it a good favor.
Step 3-Repeat steps 1 and 2 over agai
Step 4-Let dry
I swear to the word that this will clean them better than anything else you used before.
I will have after pics soon but here is a before pic-
I got one question to all of you, My front passenger side floor mat is bend in several places. How would i correct this? I've tried putting it under things to flatten it, tried bending it back, everything. My next idea is to try to heat up the plastic backing to where it will bend back, would this word????
Thanks,
Shane
Step 4-Let dry
Thanks,
Shane
Car: '81 Trans Am
Engine: 6.6L
Transmission: auto 350
this is the same cleaning method i used for my whole carpet this past fall works good huh......if you want to scrub the soap in use a hard brisle shop floor broom to grind the soap in.
Car: 1986 Trans Am
Engine: 305 LB9 TPI
the rugs came our very nicely.
The bent rug is going through treatment as we speak. Will be for a while. Under a 5 gallon bucker so it will eventually flatten.
rugs drying-
rugs dryied for show-(you can see the pool, pretty big pool, warm enough to go swimming in already, its around 60*)
the bent rug going through its correction phase-
different angle-
rugs drying-
different angle-
IROCZDAVE (88-L98)
09-17-2015 05:46 PM
