1982 T-Top latches (can I change to newer style?)
Car: 1982 CAMARO;
Engine: 1985 LB9;
Transmission: T-5/
Ok my t-tops have a hook style latch and they have they rattle and squeek like most all t-tops but with this type of latch they seem like it does it more. I would like to have latches like most of them. The tapered shaft that locks into holes, I think they hold better. anyone have any Info on this
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
You'll need the appropriate tops to go with the pin style latch, obviously. Make sure the latch receptacles match the pin diameter - there are 2 different sizes. Best to get them from the same vehicle.
Remove the A and B pillar black trim pieces, remove the existing latches (I *think* they're held on by two 10mm studs and nuts), and bolt the new ones into place, then adjust for fit.
Car: 1982 CAMARO;
Engine: 1985 LB9;
Transmission: T-5/
cool thanks for info now If i can find somewhere that sells them NEW. would be great if now the the junkyard I go
1Aauto
Sponsored Vendors
04-09-2018 03:00 PM
Black89TA
Exterior Parts for Sale
07-23-2016 10:42 AM
