taillight questions or mod help
Car: 1997 S10
Engine: 4-Cyl 2.2 Liter
Transmission: Automatic
i have a white 91 camaro and was woundering if anyone has took off the inside red or yellow plastic lense on there taillights and just left the out side clear lenses. if so how hard was it and what did you use to do it?
Car: 1989 Camaro, 2008 600RR
Engine: 311
Transmission: T-10
Axle/Gears: 02 SS Rear with 3.23 Gears
i thought they were made in red and yellow. i don't know, good question.
Supporter/Moderator
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Originally posted by 91rsowner4life
if i did that what balbs should i use
Engine: 311
Transmission: T-10
i would see about using the apc l.e.d. bulbs for our car's socket in back. bright a$$ red at night. pat
Car: 1997 S10
would those apc l.e.d. bulbs plug right in you the socket? also do they also have them for the turn signals.
Engine: 311
Transmission: T-10
i belive they do have them for the tails and the turn signals too.
pat
pat
Car: Base Firebird
Engine: TPI 350
Axle/Gears: D44
the problem with those led bulbs, though, is that they just face straight back..... they dont shoot light back into the reflective area of your inner taillights, so all you see are little bright circles in the middle of the areas that are supposed to light up..... as opposed to the whole area lighting up.....
Car: 1983 Z/28
Engine: Edelbrock 355
Axle/Gears: 3.42/Zexel/PBR
I've seen a few L E D bulbs with side facing l e ds as well, they seem to light the lense up a little better. try ebay thats where I saw them.
Car: '91 TA vert
Engine: turboLSx
I've got those matrix bulbs on the back of mine and while they do look better than the standard 18 led ones they don't hold a candle to the light dispursion(sp?) of a regular incandescent bulb... To really match the light pattern you'd need a whole board of leds like some of the newer caddys and bmw's.
Car: Base Firebird
Engine: TPI 350
Axle/Gears: D44
i'd also like to see some pics... iamsane, would it be possible for you to snap some of yours lit up at night?
Car: '91 TA vert
Engine: turboLSx
Car: 87 gta 89 ta
Engine: 5.0 5.7
Transmission: 700r4 x2
go to the southeast region message boards, if you wanna see some serious leds. some guy makes em the whole darn lens is filled with leds. im tryin too get ahold of him to make me some
