Will '89 110 Instrument Cluster Work in an '86?
Car: 1992 Camaro Z28
Engine: 406
Axle/Gears: 4.10 GM 7.5 10-bolt
I searched for hours but couln't find the answer. If everything is the same except for the '86's 85mph speedo vs. the '89's 110 speedo, can they be interchanged? Thanks.
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
Originally posted by gen3z
YUP!!!!!!!the two still use a speedo-cable so you are good to go..
Ghettobird52
07-05-2024 11:18 PM
