interior coating?
Car: 1989 Camaro, 2008 600RR
Engine: 311
Transmission: T-10
Axle/Gears: 02 SS Rear with 3.23 Gears
interior coating?
i was wondering if anyone has used truck bed coating inside their car for a way to totally eliminate the chance of rust. i have wired every square inch of the inside removing all seam seal and carpet adhesive. i was going to coat it with bed coating. good idea or not?
Car: 87 IROC Z28
Engine: Custom Forged 355
Axle/Gears: 9" 4:11's Detroit Locker
use automotive sealer on the spots where metal meets, tehn u can use undercoating on the whole thing....
Engine: 311
Transmission: T-10
great input, thanks a million you guys and gals. by the way, since i'm not running a back seat, i cut all the mounts flush, (rear seat belt, rear seat lower and upper mounts) and ground them smooth. i weighed all of these parts together and got a total weight of 13 pounds for things i didn't need to retain. just alittle food for thought for you guys looking to shave weight and don't run a back seat. again, thanks guys
Hotrodboba400
12-10-2019 07:07 PM
