Power Seats in non power seat car???
Car: 87' Iroc-Z
how does one go about wiring these bad boys up, i heard there's some kind of hoses and junk what's up with that can someone give me some hints, or what has to be done is probably a better question?
Car: 1989 Iroc-Z
Engine: 5.7L TPI
It's just two wires that you have to hook up for a standard power seat. An orange wire for power and a black wire for ground. The hoses and junk you are hearing about only apply if the seat has inflatable lumbar pads installed.
Car: 87' Iroc-Z
thanx bud i thought that hose junk sorted sounded wierd and i basically knew about the wiring....thank u for your help trickster
Car: 1985 Trans Am
Axle/Gears: 3.70
Most likely the wiring is already there under the carpet or tucked under the console. From what I've seen it was part of the harness regardless of wether the car came with a power seat or not. It may have a different connector but that's easy to overcome.
1992 Trans Am
05-10-2023 07:19 PM
colton_carlson
03-08-2019 12:21 PM
1992 Trans Am
08-08-2015 08:16 PM
