can i fit 275/40/17 or 17x8 rim?
Car: 1986 Trans Am
Engine: 305 LB9 TPI
Transmission: 700-R4
Can i put a 275/40/17 on a 17x8 in rim? I found out that SLP has new ZR1 wheels made with our backspacing for a set of 4 for $699.00. I want a wider tire that i currently have for extra traction. The best i can do is the same width. Would i be able to put these babies on there?
One set is silver
the other is "hyper black"
No pic yet for these
thanks,
shane
One set is silver
thanks,
shane
Car: 1991 Camaro Z28
Engine: 5.7L TPI
It should fit, but most likely not look or perform right. The sidwwall will be too rounded.
The widest recommended width for an 8" wheel is 255. If you want to run a 275 width tire, you really need a 9-10" wheel.
Car: 1986 Trans Am
Engine: 305 LB9 TPI
alright then that means i'm gonna get the 4th Gen Firehawk Rims
The Silver ones are still $699 which means to $174.75 per rim.
The Chrome rims are $1099 which means 274.75 per rim.
I think i'm gonna go with the silver ones though, what do you think, my car is in the sig.
Car: 85 Camaro Z-28
i just bought gm ZR1/SS style wheels, and they came w/ 275/40/17 tires. im wanting to lower my 85' Z-28 about 1 to 1.5 inches, will i have any problem rubbing, or clearing the tires? i know theyll fit under there just fine right now, but how about after i lower it?
Car: 1985 Camaro Z28/1989 Pontiac Trans Am GTA
Engine: 305 tpi/350tpi
Hey 84customZ28 any lack of performance? Any problems w/ the 8 inch rim and the 275/40/17?
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
not sure...I don't think I've put a 100 miles on them....but, ever since I've gotten the new rim/tires combo....my car has some SERIOUS wobble/vibration problems...here is a thread alllllll about it....and I need help
https://www.thirdgen.org/techbb2/sho...411post1682411
Street Lethal
04-30-2019 12:14 PM
LT1Formula
11-16-2015 01:13 PM
Djmathis123
09-29-2015 01:36 AM
