any1 in here done body work with metal?
Car: 86 Camaro
Engine: none
Transmission: none
Axle/Gears: GT4, 3:73s
i was just curious how this was accomplished because i have seen the finished product and it looks awesome. nothing against bondo(i use it too). any pics mayb?
Car: 84 camaro Z28
Engine: 434sbc
Transmission: powerglide
Axle/Gears: moser 9" with 411 posi
you don't actually grind the rust off unless it is suface rust. if you are talking about patching a panel, you have to cut the metal out. then weld in a new patch panel. then smooth it out with body filler. there is alot more to this process than what i said. i just wanted to give you a basic view of what needs to be done. i would not reccommend that a beginner tries this. as for body filler, theres nothing wrong with it when used right. when put over rust it might(if your lucky) last a year. then it will start bubbling and cracking.
Car: 86 Camaro
Engine: none
Transmission: none
patching a panel is what im talking about thanks. im sure its a long and vigorous process, i was just curious on the subject
Car: 1983 Firebird SE
Engine: 5.0L V8
Transmission: TH700R4
Me and my dad did some of that on a '83 Chevy S-10 Blazer we used to own. Its quite a bit of work, you definately have to know what your doing for it to turn out well...
Terrell351
06-13-2021 01:13 PM
sailtexas186548
Exterior Parts for Sale
02-29-2016 08:40 AM
