4th Gen Interior/Exterior compatibilty List
Old 04-07-2011, 12:50 AM
  #251
TGO - 10 Year Member
tylercamaro's Avatar
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
Transmission: TH350, 4L80E
Axle/Gears: 3.42, 3.73
Re: 4th Gen Interior/Exterior compatibilty List
Originally Posted by TIMSLOST92
Did you ever try this? I bought one on E-bay but has'nt arived yet. I found a 98 ws6 wing for a $125.00 plus a $100 to ship it. I think it will look cool on my 89 GTA
its been mentioned on thios thread before, i beleive the only ones that fit without heavy modding are the early 93-97 t/a spoliers but go back in this thread an check for sure
Old 06-29-2011, 10:35 PM
  #252
88blackiroc's Avatar
Car: 88 Iroc-z
Engine: ls1
Transmission: t56
Originally Posted by FLYNLOW92rs
I personally have a 4th Gen gas tank in my car, so yes it can be done......
Yep I did the gas tank today and it fits great! Only had to take a little bit of rubber away!
Old 07-27-2011, 08:24 PM
  #253
86yellowirocz's Avatar
Car: 1986 Yellow Iroc-Z
I still have a 86 iroc with the tpi motor and i don't plan on changing it any time soon. So would I be using the lt1 cluster for the 4th gen dash for everything to work? I wad a little lost not that.
Old 07-27-2011, 10:07 PM
  #254
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
if your switching the whole dash than yes unless you wanted to mold the 3rd into the 4th, but youd have to figure out how to make it work
Old 07-28-2011, 01:24 AM
  #255
With my iroc being a 86 would are wiring be the same?
Old 07-28-2011, 08:38 AM
  #256
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
as the 4th gens...........nooooooooo
Old 07-28-2011, 09:41 AM
  #257
Sorry I meant to say the same as you wiring write up
Old 12-23-2011, 11:16 AM
  #258
redsled87's Avatar
Car: 87 tpi iroc
Engine: 350 tpi stock
Transmission: auto for now
ok does anyone no if the rear trunk interior panels are direct fit or even close to direct fit im trying to add some t top holders ....
Old 12-23-2011, 11:59 AM
  #259
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
likely not, go pick smoe up for acheap at a junkyard and chek. im guessing not they arent exactly the same so if you were able to make it work at all yourd have to cut alot. thirdgens had t top holders
Old 12-23-2011, 05:26 PM
  #260
redsled87's Avatar
Car: 87 tpi iroc
ya a bag and strap i guess u can say a t top holder but ya i just wasnt real sure its only my 2nd third gen and the first one was a big flop it was hit pretty hard in the rear so i ditched it before i got in to deep. this is my first real camaro though i havent even picked it up yet i get this monday its my christmas present should be a lot of fun Ive wanted one for a long time
Old 12-23-2011, 05:33 PM
  #261
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
understood like i said if you can find a set of 4th gen ones cheap mod those out or something if your really tha determined on it. also take into consideration that the holders may not fit onto 3rd gen t tops
Old 12-23-2011, 05:55 PM
  #262
redsled87's Avatar
Car: 87 tpi iroc
ya thats the part i wasnt realy sure about if the t tops them selfs would even fit in those holders i guess im just looking to do something different ya know everyone has the 4th gen interiors which was my idea years ago.... (like almost 10yrs now) and now there in tons of 3rd gens ok well thanks
Old 12-27-2011, 04:27 PM
  #263
ATCFLYBOY02's Avatar
Car: 1988 Iroc-Z
Engine: 350 TPI; Stock internals
Transmission: 700r4; TCI-CPVB; BW Hi-Frition
Axle/Gears: 4th gen 7.5 w/ 3:42 gear
Cyber Grey Metallic (DuPont) and 3 coats of DuPont Clear
Attached Thumbnails 4th Gen Interior/Exterior compatibilty List-base-3-coats-clear   4th Gen Interior/Exterior compatibilty List-base-3-coats-clear   4th Gen Interior/Exterior compatibilty List-base-1-coat-clear
Old 07-04-2012, 03:45 PM
  #264
evo-offer's Avatar
wich dash,radio pod and center console is the best fitment/easiest to use in a camaro?
Old 07-04-2012, 07:11 PM
  #265
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
considering they all interchange id say roughly the same amount of work for each. if your looking for easy stick with your stock dash
Old 07-05-2012, 04:11 AM
  #266
evo-offer's Avatar
okay. i wanna change later so i´ll have to take the time and fix it then. it look soo much better.
Btw, from wich car is thhis dash,door panels and center console from and year?
Attached Thumbnails 4th Gen Interior/Exterior compatibilty List-0bb80e00.jpg
Old 07-05-2012, 12:13 PM
  #267
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
trans am/trans am/trans am. i think they only had one dash style whereas camaros had two
if anything 98-02 i know for sure dont know about 93-97
Old 09-19-2012, 12:10 PM
  #268
92camaro_man's Avatar
I need more info on your swap what all did you do to put the 4th gen gas tank in your 3rd gen?
Old 09-19-2012, 12:18 PM
  #269
can you please give me more information about the gas tank swap. Will the stock fuel sending unit fit?
Old 09-19-2012, 01:12 PM
  #270
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
do a search. its been covered a few times
Old 09-19-2012, 04:10 PM
  #271
I did a search but could not find specifics. I need to know stuff like will i have to re splice the connectors to make the 4th gen pump and sending unit work in the 3rd gen. Will there be too much pressure pumping the gas to my 305 tbi ect.
Old 09-19-2012, 04:14 PM
  #272
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
if your using the 4th gen pump on a tbi youll need a regulator. pump should be the same, in order to make the gas guage work i believe you can use a 98-02 v6 fbody snding unit and that will properly connect into the thirdgen guages. idk how to connect all the evap stuff but for lines just cut off the 4th gen plastic a little but and connect rubber hose to metal stock hardlines
Old 09-19-2012, 05:00 PM
  #273
Re: 4th gen seats
Originally Posted by wavekill00
the hassle? there is no hassle unless you want to put power ones in, its no a complicated process, and maybe if you read this thread you would have already found this out
Ive placed electric 4th gen seats in my 3rd gen. Not hard at all. Even with the wiring, nothing hard about it.
Old 09-19-2012, 05:15 PM
  #274
I will have to replace my fuel lines or can i use my current lines?
Old 09-23-2012, 10:41 AM
  #275
Car: 88 Iroc-z
Engine: ls1
Transmission: t56
It was a direct bolt in. Not sure about the wiring however, sorry. I reused the whole fourth gen harness for my swap.
Old 09-25-2012, 08:40 PM
  #276
86_irocz-28's Avatar
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
Just a shot of my 86's interior
Old 10-04-2012, 12:11 PM
  #277
Homer23's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: T-56 w/hurst short throw
Axle/Gears: unknown
It's coming along nicely. I need to add this to my growing list of mods .
Old 10-04-2012, 06:54 PM
  #278
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
just my opinion but i don't think the forth gen dashes are any more attractive than the third gen dashes.has anyone swapped in the dash from another car?
Old 10-05-2012, 08:12 PM
  #279
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Quick question:
Anyone have any in-progress pics for pretty decent fitting 98+ consoles? IDK what happened to mine... It fit pretty good in the 87, but the front has lifted a full inch in the 88? I don't think the radio pod made that much of a difference in the 87...
Currently finishing some loose ends with the 93 dash, mostly aftermarket wiring, but still need to get terminals for the C100 and the wires I need to add to it that it doesn't have (reverse lights for the T-5, for one thing). Personally, having had a 93 Grand Prix and been in J-bodies that had a gap between the front of the console and the bottom of the dash, I don't think the 3" gap (estimated) between the bottom of the 93's radio trim and the front of the 98 console is that bad. I just had to stuff the wires for the console under the carpet. Possibly a good place for gauges?
Old 10-25-2012, 01:41 PM
  #280
i thought the tbi had built in regulators?
Old 10-25-2012, 02:07 PM
  #281
goliath88's Avatar
Car: 88 firebird convertible
Engine: 305 tbi v8
so does anyone have a 4th gen dash installed ??? what else is interchangeable?? naw, im just kidding guys, but for real though, how bout weatherstripping on convertibles?? are those interchangeable?
Old 10-25-2012, 03:26 PM
  #282
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
it does but they are sorta random, some run at one pressure some at others. i took mine off my truck and put a regulator with a guage so i could read it and you can bump up the pressure a little too which helps power a little too.
Old 11-12-2012, 09:28 PM
  #283
AceBoogie!'s Avatar
Car: Camaro SS
Engine: 5.7
Transmission: 4l60e
Axle/Gears: 4.10
good information guys.
Old 11-27-2012, 01:56 PM
  #284
Engine: 2.7L V6
Axle/Gears: 4.41
Well, I got the console to fit... Took a couple hours cutting and sanding in the compartment and underneath and I ended up drilling a hole in the floor pan for a front bolt.
Wiring is finished, but I haven't tested the VSS yet. I know the reverse light switch works, though.
Moving on to the park brake lever... The switch on the back of mine broke. The lever seems to like to sit too high for my liking with the console. Assuming I keep the same cables (staying drum for now), does the complete lever assembly swap rather easily (as in bolt and go)? I'm going to have to either get the lever out of the 93 donor at the J/Y, or one or the other replacement brake light switches (I haven't wired in the 3rd gen connector to the 4th gen harness yet and/or lengthened the 4th gen wire).
Oh, and with some minor trimming to the housing, the power window switch from an 88-93 W-body fits in the hole for the 98-02 ashtray. Auto down is nice .
Old 11-27-2012, 07:26 PM
  #285
penguinpanda0's Avatar
Car: 1987 IROC-Z Camaro
Engine: 305 LB9
For the plastic gas tank swap I had to splice the connector coming out of the 3rd gen body to the connector going into the tank. I had to trim the filler neck, and since I'm using the tank on a tpi engine, I had to remove the fuel pressure regulator from the fuel pump. I also had to cut a plastic support off of the tank to make it fit. This may not be entirely necessary, but the support wasnt doing anything, so I cut it to make my life easier. If you want to know how much gas is in the tank, you'll have to get an aftermarket gauge that matches the resistance values of the new tank. I never did figure out what I had to do to make the evap system work, I'd like to know that myself actually.
I also bought some fuel hose from autozone, and clamped one end to the pump's ports, and the other ends to the metal lines of the 3rd gen. The sender line is setup on the third gen such that it screws in, so I just cut off the end of the metal line on the 3rd gen's tank and clamped the rubber fuel line to it. You absolutely do not need new lines, just about ten bucks of fuel hose.
Old 11-27-2012, 07:37 PM
  #286
Engine: 305 LB9
Also, do 4th gen front seat belts fit? I know you have to cut the notch for rear belts, but I never saw anything about the fronts.
Old 03-09-2013, 10:51 PM
  #287
Sporty-X's Avatar
Ending my 3 rd gen project car and finding that the steering column is dead. Can I use a 2000 Camaro column I have in a trashed car ? Anyone has done such a swap ?
Old 03-13-2013, 07:12 PM
  #288
Doombringer1989's Avatar
Car: 1988 firebird, 1972 lemans wagon
Engine: 3.8 V6, 350 V8
Transmission: unknown auto, TH350
Axle/Gears: factory stock for each.
I would like to know what swaps over FROM a 3rd gen into a 4th gen. I'm looking to get a 4th gen camaro or firebird V6 5 spd, and I may have found a '94 camaro, but it needs driver's side door hinges and a driver's side door latch, and all I can find online are passenger sides for some reason. I can't even find any mention of a driver's side door latch. If I can't swap them from 3rd to 4th, does anybody know where I can find these things new, just in case I get the car?
Old 03-13-2013, 07:14 PM
  #289
Sporty-X's Avatar
still asking if i can put a 4th gen steering column in a 3rd gen
Old 03-13-2013, 07:23 PM
  #290
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
read this thread and youll find out.about everything swappable has been answered in this thread
yes
Old 03-13-2013, 10:12 PM
  #291
Sporty-X's Avatar
Hello Tyler,
thx for your answer. Do you have wiring schematic so i can look how to plug the 4th gen one in my 3rd gen car ?
Old 03-13-2013, 10:53 PM
  #292
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
i do not.
Old 04-04-2013, 01:45 AM
  #293
antares57's Avatar
Car: 91 Firebird/88 Firebird/91 Formula
Engine: V6 3.1/V8 5.0/V8 5.0
Transmission: 4L60/700R4/4L60
Axle/Gears: 3.23/2.73/2.73
Are front sway bars interchangeable between 3rd and 4th gens? I've seen reference to such but nothing specific.
Old 04-04-2013, 05:28 PM
  #294
urizartommy's Avatar
Car: 1989 Chevrolet Camaro RS
Engine: 5.0
Transmission: Automatic
Axle/Gears: Stock
Any modifications needed to be done to the third gen camaro to make this work?
Old 04-04-2013, 07:20 PM
  #295
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
have to modify the filler neck basically cut the neck and use a rubber hose and two hose clamps otherwise it fits up the as well as the thirdgen one.
Old 06-25-2013, 04:30 PM
  #296
Cadaver_Puncher's Avatar
Car: 92 Camaro rs ( mostly stock for now
Engine: 3.1 v6
Transmission: 700r4 with a b&m megashifter.
Axle/Gears: whatever came stock. wanna posi tho
If I had the money it would make sense to do driveshaft, rear end and tank all at the same time.
Old 06-25-2013, 05:04 PM
  #297
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
if you had the money you call me and my work builds you a custom driveshaft that wont break easily at all!
Old 08-07-2013, 03:15 PM
  #298
BiggTipp7's Avatar
Car: 1991 Camaro RS
Engine: 3.1 V6 Auto
Axle/Gears: 3.27?
Tyler, how much would a driveshaft from your work cost?
Old 08-07-2013, 05:09 PM
  #299
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
depends on material, amount of power your pushing which dictates what u joint style to use, what yokes, what size tube etc etc. pm me and i can give you my shops number, i dont know pricing but jamie does like its the back of his hand so hed be the guy to talk to. just say that i recomended you talk to him from thirdgen.
Old 08-10-2013, 04:12 PM
  #300
livewire's Avatar
Car: 1983 Z/28
Engine: Edelbrock 355
Axle/Gears: 3.42/Zexel/PBR
Rear yes, not sure on front.
Quick Reply: 4th Gen Interior/Exterior compatibilty List
