4th Gen Interior/Exterior compatibilty List
#202
Car: 87 GTA
Re: 4th Gen Interior/Exterior compatibilty List
I started looking through this thread, to see if this has been covered already. But 11 pages & in 4 years, Mods haven't cleaned it up into a FAQ....
With a 4th gen rear, the stock 3rd gen rear offset 16" wheels are virtually a PERFECT fit & do not stick out pass the lip.
#203
Car: 1 68 bird, 2 87 birds, a 92 bird...
Engine: carb'ed 305 in the 87, yuck...
Transmission: 700R4, for now....
I have a 4th gen rear in mine and it is noticeably wider.
#204
Car: 87 GTA
I have stock 1992 rs/z28 wheels on right now and they do stick out further than the old rear, but they do not go past the fender lip. I can take a picture to show you if that would help you, other than that I guess this is beyond my expertise...what little there is....sorry I couldn't be more help...
4th gen rear, stock 3rd gen rear 16" wheels.
I'm running 17" x 9" ROH Snypers with 5" of backspacing, the blue Camaro has stock rear 91/91 16" wheels on a 4th gen rear.
There is a question of the LSx rears being a bit narrower than the LTx rears, but still wider than a 3rd gen rear, which I haven't bee able to find out yet.
#205
Car: 1986 IROC
Engine: 5.0 carb
Transmission: 700 r4
Yea its not too bad of a process. As far as I can tell, the seats are relatively the same as far as comfort is concerned. Even if the 4th gen seats were slightly more comfortable, that difference alone wouldnt be worth the time and effort (despite how little it may be) needed to do the swap, especially to go from 3rd gen cloth to 4th gen cloth. In my opinion, and probably everyone elses, the reason the swap is worth the effort is for newer, better condition, more comfortable material, A.K.A. 4th gen leather seats or to add power seats.
they arent the same at all as far as comfort is concerned they are way more comfortable. as for the difference there is none if your not putting power ones in and the hassle is like 98% effortless i could have my gf do the swap if i wanted and cars are not her strong suit at all.
#206
1 Post
Car: 1990
Axle/Gears: stock
-4th gen dashes (with some modification and wire splicing) do a search
-rear ends (with 4th gen wheels)
-4th gen wheels (only if you use adaptors(do a search for vendors), but no need on the rear if your running a 4th gen rear end)
-seatbelts
-door panels (with some modification and cutting of panels) do a search
-rear coil springs (ive been told)
-drive shaft (most 4th gens had aluminum) Im not sure if the v6 ones will work??
-LS1 and LT1 (alot of extra work and parts but can be done) see engine swap forum.
-T5 to T56 trannys (extra stuff needed) do a search
-seatbelts
#207
Car: '89 Firebird
Engine: v6
Just to start -
4th gen seats are a direct bolt in. If you get power seats from the newer car, then just wire them up like you would any other power accessory...you may even have the stock power seat wiring under your carpet.
Consoles...do NOT get the 93-96 camaro console and expect it to fit right. It leaves a large gap between the radio pod and console and doesn't fit the look of the dash at all. The 93-96 Trans Am console has 1 cup holder and the 97 - 2002 console has 4. A word of warning - these consoles are NOT direct bolt ins as many will tell you. Expect to take a rotozip to it if you want to clearance things. You may also need to move your shifter over to align it with the console opening. I have never seen a completely flush fitting 4thgen console in a 3rdgen - and I've seen quite a few from these boards that look perfect in pictures but are not. Expect to do some work if you want it even remotely close.
Here are some comparison pictures of 3rd and 4th gen consoles.
#208
Car: 1992 firebird formula
Engine: 5.7 v8 350
Transmission: automatic
this is just tempary but its a 4th gen camero center console in my 3rd gen firebird i need a 4th firebird gen console it is missing the lid the ashtray and shifter leather cover but it does look ok there is a gap between the console and radio pod i also need to make a adjustment to fit the buttons
or should i switch it to 4th gen firebird i paid 15 bucks for this
#209
Engine: 5.7 v8 350
um yeah there is a gap but it does bolt in this is a 93 camero console in my 92 firebird you gotta do with what you have i need a lid for it and shifterboot but i will upgrade to 4th gen firebird it fits plush and the gap does not look to bad
#211
Car: 1987 Trans Am
Engine: zz4 350
Axle/Gears: 2:73
Hey I saw someone mentioning this earlier on the thread but didn't see an answer,
Is the trunk trim from a 4th gen a direct swap into a 3rd gen firebird? If not how difficult is this to pull off? I've been trying to look into this for awhile without to much luck.
#212
Car: 1983 camaro
Engine: 350 soon to be 355
i have an 83 and would like to do this swap. is there something i need for the analog to digital? someone said somethign about dakota digital but i cant find anything on the site. just a question.
#213
Car: 1992 Camaro RS
Engine: 305 TBI
Ok i have read everthing here and understand everything just got one question. Which 4th gen dash/console will work the best in a 92' RS with the 305 tbi? any suggestions would be greatly appriciated.
#214
Car: 85 Sport Coupe Camaro
Engine: 1969 Camaro 350
Transmission: TH350
Axle/Gears: 3.73 Posi
So it's been a while since I posted the pics of my cars 4th gen interior, but the one thing I never did was install the A-pillars and the rear B-pillar panels. Now I hear that the A-pillar panels can be made to fit as well as the B-pillars, but does anyone have pictures of these installed in cars? I'm looking to repaint my car this summer and I'd like to finish up what I started on the interior.
#215
Car: 1983 Z28
Transmission: 700r4, 2500 stall, shift kit.
Axle/Gears: 85' iroc open diff w/3.08 gears
I'm not trying to ressurect a dead thread, but i'm interested in the corvette interior swap that someone had questioned about. is there another thread for this? search turned up nothing.
#216
Hi, I have read through this thread because I'm interested in swaping 4th gen seats for my 3rd gen seats. It seems from this thread that there is no prob with the front seats but I'm still not sure about the back seats. Someone said there would be a gap on the sides and someone else said that you had to pound the U straight or something. Can someone that has done this swap maybe post a picture of how it looks after, and what types of mods they had to do. Will the seat still be about to latch and lay down?
Also, is the alternator of a 94 V6 3.4L able to be swaped with the alternator of an 86 V6 2.8L?
Thanks!
Thanks!
#217
Thanks!
Thanks!
It's fine. Unless your super picky **** retetentive.
#218
Car: 87 GTA
Put some in & enjoy!
#219
Ok thanks for the quick replies, thats nice to know. I just bought and 86 on Sat. and I thought they looked an awful lot like my 94's seats. I think I will try the swap, I don't really care for the faded 80's red seat that are in it now.
What about the alternator? Does anyone know about that. If it would work it might save me 100.00 bucks. Right now I need all the help I can get.
#220
Car: 87 GTA
The 94 alternator would be a serpentine belt, 86 would be a v-belt, so no.
#222
Car: 1992 Camaro RS
Engine: 305 TBI
Axle/Gears: Stock Open Rearend
will the 4th gen ground effects hardware work on a 3rd gen or atleast the fender hardware anyway my car hasn't had them since my dad purchased the car from a used car dealer in 99. I wanted to get the hardware for it because I want to get rid of the zip ties I put on.
Last edited by Polo_Green92RS; 10-06-2009 at 09:36 PM. Reason: forgot to add a word
#223
1 Post
Car: 2002 Z28
Engine: 5.7 Stock
Axle/Gears: Stock
I just switched my stock 3rd gen driveshaft out today for a nice low km 4th gen piece. What an easy job. Couldn't have been simpler, even for a newbie like myself. And only about a tsp of transmission fluid leaked out (I had the rear end jacked up higher than the front). Here's a pic comparing the two. Despite the lens distortion the two driveshafts the exact same length.
#224
Car: 1988 Firebird Formula
Engine: LO3 - 305 TBI
#225
1 Post
Car: 2002 Z28
Engine: 5.7 Stock
Axle/Gears: Stock
i think i paid about $125 for it, can't recall... i seem to have lost the slight vibration i had in 5th gear... other than that, no noticeable difference... but theoretically i should be getting better fuel economy lol
#226
1 Post
Car: 1999 Camaro Z28
Engine: 5.7
I figured I'd just post a few pics of my 4th gen swap'd parts to show fitment:
Like stated, the 4th gen seats bolted right in my car. Pulled them out of a 97', the size difference wasn't even noticable honestly. They latched and folded like stock. I had a 4th gen rear in the car as well, 4th gen driveshaft, LS1/T56, dash, console. The dash/console pic was before I "finished" it up a bit. I thought my console sit very well against the floor and the new and old dash. I ran a B&M megashifter with the 4th gen console but had a boot made for it, I had to dremel the console out a bit. I also moved my window/hatch switches to the front of the console, where the TCS button or coin holder used to be.
Catbox (09-04-2024)
#227
Car: 1989 iroc z
Engine: 355 vortec hotcam tpi
Transmission: t-5
are 4th gen convertible rear seats the same as non convertible seats?
#228
what would need to do to get a 98-02 CENTER CONSOLE with the 4 cup holders to work in my automatic????
i see a lot of you have stick so i just figured i'd ask
#229
Car: 87 GTA
It has a indicator next to it to light up the gear selection letters, but the black leather boot is the same as what a manual tranny has.
#230
#231
1 Post
Car: 88 Camaro
Engine: 2.8v6
Transmission: 700 R4
New guy jumping on an old thread. Just found another thread about the exterior window sweeps fitting with very little work. I would like to try the steering column swap in my son's car. It's his first ride, and does not have tilt. I have found two pretty complete 4th gens in a local yard and this thread has me getting all kinds of ideas. I am for sure doing the seats and belts cause his belts are messed up and he will be able to adjust the newer seats better so it's kind of a safety thing to me. Thanks for all the great info.
#232
#233
Car: 87 GTA
just read the new hpp and they use the ABBOTT CABLE-X
www.abbott-tach.com
www.abbott-tach.com
Cable from the tranny, up to the dash. Into a device that converts the mechanical signal into an electronic output, running a motor that operates thge gauges.
#234
Car: Purple & Black 1984 Trans Am T-Top
Transmission: Automatic
This would be GREAT if converted to an FAQ! Difficult to sort through all the info, and some is conflicting. I'm just saying would be helpful. Still not 100% sure that 4th Gen belts will install seamlessly into my 84 TA T-Top. Also, does anyone know how easy/difficult it would be to convert the 2 point backseat belts to 3 point belts? Lots of 4ths gen belt sets have 3 point back belts. Thanks in advance!
#235
Car: 87 GTA
89+ 3rd gens had a 3pt too, so you cannibalize one to get the parts. But the rear shoulder mount is welded in to place, so you'd hafta chisel it off them weld it on to your car.
#236
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
(I have a spare set in black for sale by the way)
#239
I have a 4th gen 98 z28 steering colum in my 84 and the only thing that was different was the wiper switch wires, everything else was direct plug and play
#240
Car: 1989 irocz
Engine: 305 ho
Transmission: t5
ive spent about 2 hrs reading this and i know you can use 4 gen rear ends but can you just use the disk backing plate and brakes on 3rd rear end
#242
Can I swap a hard top for a T-top??? In other words can i cut a T-top off one car and put it on one that is a std hard top?? Not sure how to start a new stream else I would have.
TX
DG
TX
DG
#243
Car: 87 GTA
I forget who here on TGO has done it, but IIRC.....Hardtop to T-top to Convertible to "wrecked" before being finished to scrapped. And it all has pics here on TGO.
#244
1 Post
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
a t top/convertable camaro has reinforced rocker panels under the car.at the least you would need weld in subframe connectors.
#245
Car: 1994 Camaro Z28 B4C T-tops,
Engine: LT1 350 5.7L 116K
Transmission: 4L60E (being rebuilt)
Axle/Gears: 3.23 Posi
does anyone have any pics of a FULLY transfered 4th gen int into a thirdgen? i want to do this swap myself,
dash, door panels, console, seats, belts, sils, t top pillars, everything that can be swapped i want to swap it, ive got an 84 camaro z28 with a 355, how can i do this?
i would want all guages to work speedo, tach etc, im running a th350, is there anyway to do this?
#246
This is correct, the gauges are electronic in the dash (except possibly the speedo and/or odometer). Based on my limited experience of pullying out 3 dash clusters on 86, 86, and 88 Z's
#247
#249
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Made a thread on swapping 4th gen window sweeps:
https://www.thirdgen.org/forums/body...en-window.html
#250
Did you ever try this? I bought one on E-bay but has'nt arived yet. I found a 98 ws6 wing for a $125.00 plus a $100 to ship it. I think it will look cool on my 89 GTA
