4th Gen Interior/Exterior compatibilty List
#151
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
Here's a pic of the 4th gen belt and 82 sill plate installed. Worked out well for me. The 4th gen belt retracts so easily compaired to my old ones. Had to pull lthe seat out to get everything in, now time for a little cleaning/vacuming and it will be done.
#152
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
#153
I've put in the 4th gen brake handle. It bolts right in. Although I'm using 4th gen e-brake cables from the handle to the rear disk brakes. The cables are the tricky part, you have to make your own e-brake braket(for underneath car) or get one cut out from a 4th gen.
#154
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
well i just put in all new e-brake cables but they arent for 4th gen, they are just replacements for my 86. i have the 4th gen e-brake handle, and whole assembly unit i got from a 2001 camaro. so this will all bolt right in, just wondering if the cable will hook up to the 4th gen assembly unit with ease, im sure i can think of something if not.
#155
Car: 1986 Firebird
Engine: 2.8
Axle/Gears: 3.42s
Re: 4th Gen Interior/Exterior compatibilty List
I have looked thru here many times and havent seen anything and maybe i missed it but what are the mods needed to install the 4th gen dash.. not electrically but physically. and does anybody have any pics of 4th gen door panels on their car?
#156
Car: 13 Ford Focus SE / 90 Camaro RS
Engine: 122 I4 / 305 V8
Transmission: DCT / 700R4
Axle/Gears: 3.895 / 2.73
Very interesting thread. I was just looking to put in 4th gen seats but now that I know you can basically get the dash and console to fit my 3rd gen I'm going to definately do that now.
My question is to the people who've successfully done the 4th gen dash/console swap; what year donor car did you use and what was the biggest headache involved in doing the swap? I'd like to know what the BEST year(s) is(are) to put in my '90 RS Automatic with the least amount of headaches.
#158
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Then you just have to modify the two brackets on the edges of the dash (next to the kickpanels) to match the studs on the body.
#159
Car: 1992 Chevrolet RS Camaro
Engine: 305 TBI
Transmission: WC T5 conversion
Axle/Gears: Debatable . . .
The dash pretty much bolts right in, just need to drill a few holes in the upper firewall area(right under the windshield) to match the holes in the 4th gen dash since they were spaced a few inches different.
That's it? I would have thought some cutting would be needed with that gigantic dash.
#160
Car: 1986 z28 <sold>
Engine: iron head 383
Transmission: th350
Axle/Gears: 4th gen 3.23 posi
heres one for ya wil 4th gen carpet wrk in our cars at all like even remotely?? if so how?
#161
Well....it would physically sit in the car, but nothing would fit the way you want it to... Floor pans are different enough along with other things that it wont fit.
alloy!!!!!!! That is the best piece of info Ive seen yet!!!! I never knew the 82's were like that. I never did take the retractor covers apart to try to make them work, but I like this idea 1000 times better. Wow...good stuff!!
Justin
Justin
#162
Car: 87 firebird none soon
Engine: None
Transmission: none
Axle/Gears: 2.73 10 bolt
someone already said that the 4th gen kick panel works so you don't have to get one out of an 82
i think some of you guys should just buy a whole 4th gen you'll spend less if you get a v6 at least if you got one from mass sad a 96 bird for 900 once pul the interior and whatever else then junk or part it
#163
Car: 92 RS
Engine: L03 with Holley Sniper EFI, headers
Transmission: T-5, hurst billet shifter
Axle/Gears: 3.08 posi
For the rear seats, watch out for the center bolt. The nut is only tack welded and it is easy to break off if you cross thread the bolt. It is a real PITA to get the bolt back on once the tack weld breaks. Just be careful when tightening it.
For wiring the power seats, I just hooked the ground up to the bolt and the positive up to the stereo power lead. It is real easy to thread the wire under the console to the stereo lead, and you know the wire is fused.
#164
Car: 89 Formula Ws6
Engine: 358 Tbi
Axle/Gears: stock 2.73 posi
you dont have a mechanical tach and speedo they changed to electric in 86
#165
Car: 89 Formula Ws6
Engine: 358 Tbi
the door panels will fit with the 3rd gen dash with the propper trimming and will still look fine when you put the 4th gen dash in if you decide to.
#166
Car: 92 WS6 Trans am convertible
Engine: ls 6.2
Transmission: 4l80
Axle/Gears: 2.73's
#167
Car: 87 IROC-Z28
#168
i have an 86 camaro iroc and ne ways the dash pad or w/e is all cracked and **** so i have a 91 firebird formula thats recked but the dash pad is the same except for a few things i guess....what can i do to make the dash from the firebird work in th camaro??
#169
#170
Car: 89 Formula Ws6
Engine: 358 Tbi
what all is cracked just the dash pad or the hole dash. The dash pads are exactly the same with the same bolt pattern.
#171
Car: 86 Trans Am,03 Yukon,92 Z28
Engine: 5.3, 5.3, lb9
Transmission: th350,4l60e,700r4
Axle/Gears: 3.73,3.73,2.73
not all are some of the camaro ones have a cut out looking thing on the pad for right above the vents in a camaro the birds dont have this thats the only differance i can think of
#172
Car: 89 Formula Ws6
Engine: 358 Tbi
#173
im asuming the bolt pattern is the same but physicly there a lil diff
#174
ya i cant get it to fit...its a lil smaller also. of course the firebird i took it out of was a formula idk if that makes a difference...i think im prolly going to just get a dash repair kit or something. i wanna try putting the 4th gen dash and center councle in it sometime..that would be neat.
#175
Car: '89 GTA/'86 TA/98 TA
Engine: 350/350/LS1
Transmission: R4/T5/4L60E
Axle/Gears: 3.23/2.77/3.73
K search the thread thouroughly but nothing on the trunk panels.
Do they fit??? I want to get that sub enclosures that go into the side panels from MTX cause no other companies make it as my research showed. The only problem is they dont make a product for our cars anymore(I think). I have not called them.
Anyone done it??
Anyone done it??
#176
I work at Advance Auto, so I have a bit of time so look up aftermarket conversions. I'm pretty sure I ran across all 3rd and 4th gen driveshafts, auto and standard, 6 and 8 cyl., being the same, but somebody back me up here. I'll do some research and try to post back about anything else I happen upon.
#177
the driveshafts work im running ls1 aluminum driveshafts in my 82 and 86 t/a
#178
Engine: 350/350/LS1
Any word on those back panels
#179
sail panels wont unless you want a six plus in. gap as far as the rest it would probably be close. the 4th gen rear peice is only a hdf coverd peice but looks almost the same. in the procses of putting my dash now
#180
Car: 1990 IROC-Z Camaro
Axle/Gears: 10 bolt
Will a 4gen auto shifter fit in a 3rdgen console?
#181
#182
Engine: 350/350/LS1
It will work but theres lots of cutting to do on it
#183
Axle/Gears: 10 bolt
Does any one have any pics of the 4gen shifter in a 3gen. What requires cutting the console??
#184
Car: 89 Formula Ws6
Engine: 358 Tbi
the third gen shifter works if you move the shifer down i have the fourth gen console in my 89 and im still using my stock shifter
#185
Axle/Gears: 10 bolt
I have a aluminum drive shaft out of a 2002 m6 camaro are they any way to make it fit my 1988 camaro it has a 700r4 trans and a 10 bolt rear end.
#186
bolts right up ive got em in both my thridgens
#187
Axle/Gears: 10 bolt
you have the shifter or driveshaft in your cars?
#189
1 Post
Car: '86 Trans Am
Engine: 305 H.O.
Sorry to annoy anyone if this does, but I've sifted through here and was kind of confused by all the talk about the consoles... but...
I have an '86 T/A (auto) and was wondering if I could just bolt in a 4th gen center console without having to revert back to manual windows.
#190
Car: 89 Formula Ws6
Engine: 358 Tbi
#191
Car: 85 IROC "SYNASTR-Z"
Engine: 355 SBC
Transmission: 700-r4
Axle/Gears: 3:73 disc brake
Ok i cant find this. i took power leather seats and belts out of a 95 camaro. I have an 87 ta. I hooked the front driver up by changing to the fourth gen connector (i had GTA seats). The back lower seats didnt wanna work, i bolted it in and it stuck up so i had to hammer the U straight. Now they work. The front seat belts( my question) are different. Where the clip holder is different. It has a 45 degree bend and my 87 doesnt, its straight. Can i just remove the cover and bend it straight? And since my car has the floor mounted retraction thing, would it still bolt up even if i get 82 panels?
#192
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Seat belt points are all the same, not sure what you are talking about with the 45 degree bend. The 82 panels should basically be the same as the rest except do not have the notch cut out where the retractor would be. Essentially they would cover the retractor hole.
#193
i have the driveshaft in my cars
#194
hi i have an 86 camaro will the interior harness form a 4th gen work im my 3rdgen i want to switch them becauseim putting in a lt1 and i want to make a dash and i have 95 z28 gauges and also will the steering columns swap between the two?
#195
Engine: 355 SBC
Idk the belt that mounts right by the center console (the latch) on the fourth is bent and wouldnt fit due to the bend in it and it hits the seat. the side on mine has the retractor there and has that big notch. Also my rear seat belts mount down by the seats and the fourth mounted up on the fender well.
#196
Car: Black 1989 Formula Firebird
Engine: 5.0 TBI soon to be LT1
Transmission: 700r4 soon to be T56
when you click on this link WWW.TransAmWS6.Com okay a logo or a picture shows up of a third gen with a 4thgen either retro fitted or something i really like it.. is it possible or what???
#197
Car: 92 Firebird
Engine: 4.8 LR4
#198
Car: 1985 Camaro Z28
Engine: 5.7 Liter
Axle/Gears: 10 bolt 3.55 POSI
4th gen seats
How much more comfortable are the 4th gen seats than the 3rd gen? is it even worth the hassel?
#199
Car: 1986 IROC
Engine: 5.0 carb
Transmission: 700 r4
Re: 4th gen seats
#200
1 Post
Car: 91 rs
Engine: 5.7 350 :))
Axle/Gears: 1996 - 3.42
Yea its not too bad of a process. As far as I can tell, the seats are relatively the same as far as comfort is concerned. Even if the 4th gen seats were slightly more comfortable, that difference alone wouldnt be worth the time and effort (despite how little it may be) needed to do the swap, especially to go from 3rd gen cloth to 4th gen cloth. In my opinion, and probably everyone elses, the reason the swap is worth the effort is for newer, better condition, more comfortable material, A.K.A. 4th gen leather seats or to add power seats.
