4th Gen Interior/Exterior compatibilty List
#51
Originally posted by 67 Camaro 88
The handle I got (not sure if they are all the same) are 100% identical to thirdgens... just minus the rectangular indention (cosmetic). It's smooth.
-Bud
-Bud
Cool deal.
Even behind the handles are the same? (IE how it mounts). I absolutely HATE those push on connectors. I used just some standard sized nuts behind the push-ons, but my handles STILL came loose.
#52
1 Post
Car: Camaro
Engine: 3800
I found that my handles were loose because the pot metal had worn out. The actual hinge nipple parts inside. It's held on the same way my old ones were... two of those stamped 1/2 nut deals.
-Bud
-Bud
#53
Car: '89 Black 305 TBI Firebird "Eleanor"
Engine: V8 5.0L (LO3)
Transmission: T5 Manual (hurst shifter)
if you do a 4th gen center console swap, is it better to go ahead and swap the radio console too?
#54
Car: 2002 Formula Firebird
Transmission: 4l60e
The 4th gen seatbelts do fit even thought they are a different design. The top part is the same as well as the buckle part. However the piece that bolts down by the seat is slightly different. I cut my stock 3rd gen cover so I could take it off the old belts and put it over my new one to make it look as stock as possible. I will try to get some pics.
#55
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
if you're swaping 4th gen console to thirdgen dash/radio pod, you won't have a problem .... if you have a firebird.
With a camaro, you'd need a firebird radio pod. Although i'm sure this info is out there somewhere, might as well take care of it in this post as well.
a 3rd gen radio pod from a bird will mate up to the bottom of the 4th gen console pretty decnetly, and in 4th gens, there is no seperate radio pod, if you're planning on doing that, you're doing a dash swap, no other way around it.
Also, automatic 4th gen consoles can be used. But, it does require some modification to the shifter location, the transmission hump in the floor, some grinding on high points in the shifter, stretching the shifter cables, and trimming some fat off the console.
My 01' camaro console was in flush as it could be, looked really nice, however, i recently swapped to a 96 bird console because of my 95 dash (needed things to match in fit and color) looks much nicer.
If you modify your 98+ console, shifter, etc to fit a 98+ automatic, it'll clear a 93-97 console without any inconvience (whatsoever) infact, my 93-97 console dropped in like it was supposed to be there, and looks just about as factory as i'd expect. The only small gap is between the carpet on the pass. side where it doesn't align with the curve of the floor, can be fixed by building up the carpet in that location.
If you have an automatic firebird/maro, it'll be worth the extra time (and it does take a little time) to get the automatic 4th gen console installed. However the look of the console far outweighs the time, and the look is very worthwhile.
Another swapable item (if your interested) are the rear views. I swapped in a rearview to my 85. It's one of the parts on a 4th gen that is normally in good condition, they also have reading lamps on both lights. Run the wires to your dome, and you've got light when you open the door, and light when you press the button, plus they're normally in better condition than the 12-22 year old mirror in your thirdgen, also a tad more round, which cuts down on the "squareness" of the rides.
#57
Car: 1985 Camaro, 1986 Trans Am
Engine: 5.0L carbed and 5.0L TPI
Transmission: TH700R4
Axle/Gears: 3.23 and 3.27 posi
#58
Car: 84Z & Porsche
Engine: 427sbc - 471 - 850 Demon Claw
Transmission: Bowtie stage II TH700R4 - 10" 3000
Axle/Gears: 9 Bolt w/ 3:45's
4th Gen to 3rd. Gen
I have 4th. Gen LT1/ws6 16" X 8"(salad shooter) ten spokes on my 84 z28. The rear is a 9Bolt with LT1 brakes, the front so far is OEM (except rebult calipers and cross driled rotors, pads etc.). With 2" spacers they fit just right. I went to 235/55/16 (from the OEM 235/60/15) so the outer diameter would be the same at 26.1" (speedo would still be accurate). Soon to up-grade the front brakes to 12" & Dual piston set-up.
#59
Car: 91 Firebird
Engine: 350 - FB heads - TPIS
Hey 85f-bird!
My original manual console has had it, so i found a 98+ manual console on ebay. After spending some time trying to install it i had a question i was hoping you could answer for me.
When i push the console forward as necessary for the e-brake to go down level this lines up the bolt holes to mount it properly. However the radio pod is pushing down so hard on the front of the console that it requires too much force to put the rear of the console down to the tranny tunnel
Is this normal with this kind of install? If so is there anything to be done about it.
Any suggestions would be appreciated
#61
Car: 1 68 bird, 2 87 birds, a 92 bird...
Engine: carb'ed 305 in the 87, yuck...
Transmission: 700R4, for now....
Originally posted by weberusn
are there any how to's on 4th gen dash installs?
#62
Car: An '87 Italian Retard Out Cruisin'
Engine: LS1 install in progress
Transmission: 4L60e
Axle/Gears: 9 bolt
Originally posted by bottledbird68
I second that one!!! I just happen to have a dash sitting in the trailer outside the shop.....
#63
Re: E brake handle
Originally posted by scooter
Anyone know if the 4th gen ebrake hadle works? I think it is close at the very least but I was just wondering if the bolt hole lines upon the metal or not. Mine is getting a little cracked in the leather at this point. No sense spending money to get it recovered. What is a good price to pay for them also?
nope the brake handle will not bolt up, you will need the entire lever from a 4th gen......
#64
Engine: 2.8L, LS1
for black91, with the center console top cover removed how does it sit? IF things are in place, it should just fall into place, there might be a problem with your radio box alignment forcing it to sit lower. When i installed my 98+ console, i pushed it all the way forward, made sure it wasn't touching either seat belt (which it would try to do all the time) and lowered it into place. You'll have to get the e-brake through first of course, which requires it being pulled as high as it can freakin go, but the rest of the push down bolt in was a no brainer, and a no prob.
To Web and Bottled Bird, do a search, im sure there are a few on there about how to swap it, the swap is essentially pretty easy, there may a tad bit of cutting required to get everything to sit the way you want it to, however, it's really no big deal, easier than an automatic center console, however more time consuming.
#65
Car: 86 Trans Am,03 Yukon,92 Z28
Engine: 5.3, 5.3, lb9
Transmission: th350,4l60e,700r4
Axle/Gears: 3.73,3.73,2.73
i was plannig on doing the consol swap to 4th gen cause mine is falling appart badly and i had heard that it is better to find a manual tranny counsol for the 700r4 3rd gens because it fits better help?
#66
#67
so the manual counsol from a 4th gen would be best and is there iny way to set up a gear indicator?
#68
Car: 1989 Formula 350
Engine: Stealth Rammed 350
Axle/Gears: 3.45 9 bolt
Are there any aftermarket Manual shifters that will not work with a 99 Camaro 6 speed console? I dont wanna put one in and crack the console. thanx.
Console is now INstalled. Had to bump it forward a lil bit so the screws would line up but thats the only problem. Now i just need to fab something for the power window switches. Easiest Mod ever. and it looks totally awesome.
#69
Engine: 2.8L, LS1
to screamin, you can use the manual console, getting a shift indicator will be a fabrication job, which is exactly why i did the automatic console swap. Looks a tad more stock than using the manual boot over the auto console IMO. its a tad more difficult to do, but worth it if you've got the time an energy, if not, use the manual console, not much if anything needs to be changed from what i've heard, and you'd just have to live w/ not knowing if ur in drive or overdrive, or memorize the position of the shifter lever.
#70
well if i could get some info on how some of you have done the 4th gen auto console swap because i would like it to look original i mean if i have to i already know what gear im in by how far the shifter sits back but that would be great if i could get some info
#71
Engine: 2.8L, LS1
its actually kind of a lot to post...i've posted it once myself, atleast, probably twice or more...and i actually found a good post on the site also when i did mine...use the search button, shouldn't be to hard to find.
#72
Car: 91RS_92Z28
Engine: 5.0_5.7
Transmission: WCT5_WCT5
Axle/Gears: 3.08_3.42
The center caps from the 4th gen camaro wheels are identical to the 91-92 Z28 wheel's center cap.
#73
Car: 84-88 Pontaic Trans Am Convertable, 88 S-10 350, 89 S10 2.5L
Engine: 383 - 475 hp 485 ft lbs
Transmission: WC T5
Axle/Gears: 9 Bolt
Are the 4th gen rear seats a easy bolt on? How about the steering coloum will it fit?
#74
1 Post
Car: 87-Z r.i.p & 93-Z sold 99s-10
Engine: 305 TPI , 350 LT1, 2.2 4cylinder
Transmission: 700 R4, 4l60, ?
yeah da rear 4th gen seats will fit perfect on a 3 rd gen...i did it and was so easy and i got leather ones so it was so worth it "beautiful" . i also got a LS1 ss aluminum driveshaft easy install in the 3rd gen "beautiful" ..........so is everything on the axles of both interchangeable ? hatch struts ?
#75
Car: 1987 Camaro Sport Coupe 'Vert
Engine: 350 replaced for orig 305
Transmission: Auto/Overdrive
I want to replace the stock grey cloth seats in my 1988 Firebird with 4th gen leather ones. Anyone know if they made light grey leather seats and if so what years? I've seen dark grey and black/ebony on Ebay. Or better yet, if anyone has info to share on color/year combinations that'd be great. Link to another site that has this info already???
#76
go a 4th gen console question. The wireing from my old cigarette lightws is no where near what the wireing on the new one looks like. Is there anyway to get the cigarette light and the power port to work or do i need to buy the connecter from a 99 z-28 and splice it in somehow?
#77
Car: 91 formula
Transmission: t5
1 power is prolly for the cig lighter itself... and second is a parking light wire so that there is a illumination ring around it when the lights are on....
#78
Car: '91 Firebird
Anyone ever tried the kick panels from a 4th gen?
The metal brace for mounting the dash has a few mounting points on it:
-Steering Column
-Behind console
-Passenger Side
-Drivers Side
The 3rd gen kick panels are in the way of the side mounts... was hoping 4th gens were a close fit.
-Steering Column
-Behind console
-Passenger Side
-Drivers Side
#79
Car: 89 Firebird
Engine: L05 350 TBI
Transmission: 700r4-slippin' on it's last leg
Originally posted by white91formula
2 power 1 ground
2 power 1 ground
#80
Originally posted by jconrad
...When I needed a switch illuminated like that, I found the grey wire on my rear defrost switch that goes to the dimmer circuit. I tapped into that, and now my new switch illuminates, and dims.
#81
Car: '91 Firebird
Looks to me like the kick panels will work too.
They're the same piece as part of the door sill though. May need to cut that part off...or use it and cut off part of the 3rd gen doorsill. But otherwise they seem to fit OK (and they cover up the new dash's mounting points.) Also, you will need the 4thgen's hood release.
#83
Engine: 2.8L, LS1
as i recal, the door sills do fit, as i've had them on mine for test fitting once, don't remember why we didn't leave them. Pretty much straight forward. Who did the A-pilars? I had mocked some up a long time before, and things actually seemed to workout pretty well, but there was an unfortunate and that's the angle between the pillar and the t-top, that seems a tad off, and i'm having a bit of trouble trimming that to fit, or figuiring how to trim it to fit. So my Q to him is, did he have a hardtop?
#84
Car: Silver 1980 Corvette (L82 w/TPI)
Engine: L82
Transmission: TH350
Originally posted by 88IROCARMY
4th Gen Automatic Trans Shift Handles can be used on the 3rd Gen. I have a 4th Gen Firebird "Side -Button" that replaced my 3rd Gen Camaro "Top-Button".
4th Gen inside mirrors with the map lights can be used on 3rd Gen.
4th Gen radios (I think???)
Now- the next few aren't 4th gen Fbody parts-
Power window switches from a C5 may be well worth the trouble if you are doing a compleyely custom interior. C5 corvette's have a great power window switch. It is totally covered in rubber on the buttons and lasts a lot loner than 4th gen cheapo plastic rockers. You will need GREAT fabrication skills to get it to fit. Who knows- you may want that feature if you are using Corvette parts.
Another cool idea for a SERIOUS custom job- C5 wheel pressure sensors. Again, this will require a dash swap. You could also use the HUD display- but you'd need to play with the angle of the throw of the image on the windshield.
Corvette 1978-82 wheels are direct fits for early z28s. I don't know if you want 15x8s- but they will fit... as will Corvette rallyes.
http://www.ecklers.com/product.asp?d...AUGHMG39J1BK58
or
Word of caution- I had a problem with the carpet I replaced in a 1993 z28 from ACC. It was about a three inches to short in the rear cargo area and not deep enough under the rear seats. Third gens may have similar issues- this is typical of aftermarket stuff.
I think the C5 seats will swap as well with only minor adjustments to get them to fit the stock tracks.
If you want a neat way to get a mini- glove with doors into the rear cargo area (like to cover up amps or something) use 1968-82 corvette cargo doors. You'll need a frame to support the door frame, but the cost is about 175 for fully finished and hinged doors. Serious custom job- but may add the right touch.
#85
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
steering wheel
4th gen steering wheel works great. For those with airbags, get the electrical connector (both ends) from the 4th gen donor car, as the connectors in 4th gens were different (smaller), and it's easier to replace the column's connector end than the bag's connector end.
#86
or
or
#88
Car: on the hunt for a 3rd gen again
ok....if you have a 3rd gen CAMARO (mines a 90 automatic btw) what all do you have to cut/trim/buy in order to get the 4th gen automatic console from a firebird to get it to fit flush?how hard is it to get the shifter/ebrake to fit?thanks in advance, and id appreciate it if someone could answer these straightforward and thorough.TIA again.
p.s. what about the 4th gen sun visors?i like the mirrors they have as mine doesn't have any
#89
Car: 84Z & Porsche
ThirdGen wheels are 0 offset and 5" back space rear, and 5.5" back space front...
#90
Engine: 2.8L, LS1
traksta, don't wanna sound like an "***" or anything, but did you do a search?
I know when i did my 4th gen console i found an post that i based everything on, after finishing my console, im pretty sure i wrote a post describing what i did also...it's a lot of banging, test fitting, more banging, drilling, cutting, test fitting, more cutting, more test fitting, and trimming. Takes a little while, mine was about a day and a half for the swap.
Mods were (off the top of my head) tranny tunnel (banged down) new holes drilled in floor for shifter, shifter cutdown along the high points, shifter plate on the console (trimmed down), installed shifter boot, then spliced the cigerette lighter. IT's not that hard, just time consuming. but like i said, do a search, it's more detailed than that.
#92
Car: 85 Trans Am
Engine: 305 Carb
Again, a is your best friend. I remembered reading something on this and was able to find this thread very easily.
#93
Originally posted by traksta15
any info on the visors?
#94
Car: 85 Sport Coupe Camaro
Engine: 1969 Camaro 350
Transmission: TH350
Axle/Gears: 3.73 Posi
I know I'm reviving an old thread here but I figured I'd share my experiance.
I have a mega shifter in my third gen and when I installed my 02 TA console I saw it didnt fit as well. The shifter as it was installed in the 3rd gen will not work its to wide and to tall. So all you have to do to make it fit is 3 simply things.
1- Remove the bracketry that came with the B&M shifter it raises the shifter about an 1 1/2(in) from the normal bolting point. Once these are removed use the factory bolt for the shifter in the upper right hand bolt hole (towards the passenger side) then use self tapping screws on the left side of the shifter and screw it to the stock framing for the orginal shifter (you will have to make new holes in the shifter and the floor panel, which the self tapping screws will do for you).
2- you will have to use a file and file away some plastic on the manual shifter opening. The place you will file is the front and back of the opening where the shifter will sit. There are currently tabs there for the boot to snap in. Once you file away these tabs the shifter will sit right (NOTE: do not file to deep there is no need to file the actual console just the tabs) When finished you will be able to ratchet action your mega shifter just as you did before and everything will clear.
3- If you want to use the manual boot from the 4th gen console (like I did) you have to cut the threading holding the boot together towards the top. Since the mega shifter has such a large width at the top the 4th gen boot will not just slide over it. If you cut away the threading at the top of the boot about an inch down you can then slide the boot over the mega shifter. I just folded the excess boot material down inside the boot itself to give it a nice clean look.(NOTE: you will not be able to snap the boot into place on the console like it is supposed to. You will have to tuck it under the console and 'fluff' it out to cover the tabs in the opening. If you don't do this when you ratchet action your shifter you will pull up on the boot causing the console to pull up with it)
So if you have a mega shifter and want to use a 4th gen dash IT CAN BE DONE EASILY. So don't let that stop you.
4th gen 97 manual console to B&M megashifter = disaster waiting to happen ( I cracked my console, its basically too big).. it may be possible, but I add that to my list of 3rd gen failures.
#96
Transmission: TH350
Sure not a problem. I'll go take a pic and then post it in a little bit.
85 Camaro Sport Coupe
-91 Z28 Grd Efxs
-69 358, 255 rwhp
-TH350 trans
-97 Trans Am Interior
98 SVT Contour #49 of 6535
-91 Z28 Grd Efxs
-69 358, 255 rwhp
-TH350 trans
#97
Transmission: TH350
Here you go man hope this tickles your fancy.
It can be done, enjoy!
-Mike
-Mike
#100
Transmission: TH350
Originally posted by 83 Crossfire TA
What switches are those in front of the shifter? The ones with the blue stripe (indicator light?) on either side?
Originally posted by camaronewbie
That's a complete 4th gen dash replacement, isn't it?
-Mike
