Sil panel
Sil panel
Not sure what the correct name (sil panel) where you place the stock jack that came with the car. To cut a long story short had another jack under the crossmember of the car but have to use the side jack too becuase other wise the car sits too low and can't get the crossmember jack out.
Anyway dad was lowering the car back down and had the side jack in the wrong position just as I came out let the cross member jack down but not slowly and the car fell on the side jack right in line with the Z28 emblem behind the GFX. This pushed the GFX panel up and now is rubbing on the bottom of the door. Also the front fender is now rubbing on the door when you open it. Not much but you can see the fender flexing a little when you open the door.
Am I able to repair this myself? Hammer it back down or will I need to take somewhere to get fixed. Can it be fixed is my next question and would it be costly/ lot of work involved?
Pi$$ed me right off perfectly straight car and now this.
Mike
Mike
formula00ra
Interior Parts Wanted
09-28-2015 11:50 AM
