Can door moldings come off and be reused?
Old 01-23-2004 | 12:08 AM
Stingraye's Avatar
Car: 1986 Trans Am
Engine: 350 W/Plenty of Mods
As the title asks, has anyone taken the edge guards off of a thirdgen and been able to reuse them? I noticed they are like $32 a peice just for the fender and Q-Panel peices, so I'm thinkin about goin to a yard and tryin to find them, but need to know what I can do to be able to ensure they will still be able to be reused. Thanks.
Old 01-23-2004 | 12:11 AM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
if you can get the adhedsive crap off the back they can be reused just fine, i had a peice missing on my drivers door that was in the back i used it and it looks great
Old 01-23-2004 | 04:42 AM
BLACK ICE's Avatar
Car: 91 RS
Axle/Gears: 10 bolt
I think it looks better without it!
Old 01-23-2004 | 01:24 PM
TX_1987_GTA's Avatar
Car: 1987 GTA Hardtop
Engine: 350 T. P. I.
yes they can.....
most body shops re-use them all the time, like stated before if you clean the adhesive tape from them all you have to do is replace the adhesive tape to the molding and your good to go. My suggestion is get the moldings then take them to a local automotive paint store, show them what your trying to do & they can usually sell you all the proper solvents & proper adhesive tape to re-apply the moldings. But I will say that I agree with BLACK ICE, I think they look cleaner without them. Good Luck.....
Old 01-26-2004 | 09:49 PM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
I thought my T/A would look better without them so I didn't have the guy put them on after it was repainted. Now I feel different. The door is just to big and there's nothing to break it up. My body man said its best to replace them because he said its difficult to remove them without creasing them. He said some of them have a metal rod in the center that helps keep the straight. My car is going back into the shop in a few weeks, my cousin backed into my car 1 month after i got it back.
It's also getting the wing put on it and some small stuff fixed that I am not happy with. Ohhhhhhhhh I can't wait.
:lala:
Old 01-26-2004 | 11:14 PM
86IROCKET-Z's Avatar
Car: 1989 Toyota Supra Turbo
Engine: 7M-GTE
Transmission: R154
Axle/Gears: 3.91 LSD
The door just looks so much better without those stupid moldings on there. It looks like the was it should have been. I'd say that you should try it without all the moldings on, and see what you think. I know that i'm not putting mine back on whenever i'm done..
Old 01-27-2004 | 12:51 AM
LilJayV10's Avatar
Engine: 406 Roller
Maybe a pin stripe or something? the car needs something.
b4ccamaro
06-05-2016 02:48 PM
tglennon11
09-23-2015 06:30 PM
WhteRbt
09-21-2015 10:48 AM
