91 gauges in 86?
Car: 91Z28, 94 Silverado, 99Z28
Engine: 350 TPI, 350 TBI, LS1
Transmission: 700R4, 4L60E, 6-speed
Axle/Gears: 3.42, 3.42, 3.42
91 gauges in 86?
Is it possible to put the gauge cluster from a 91-92 camaro into an 86 camaro? if so what will i need to complete this other then the cluster itself.
wow, i think you would have to do alot of change's. 1st, no speedo cable in 1991. electric vss. i think you would have to change some location's of the pin. better get some wiring charts to see if its possible. best of luck, tom
I'm actually planning attempting to do this in my 84 this summer.
From what I've read, you will need to replace your cable speedo with a VSS and buffer box. I've got the buffer box, are junk yards about the only place you can get the VSS? I just really don't feel like going to the yard, and having to go under the car, and trying to remove this, then get home to find out it doesn't work or something.
The instrument cluster is shaped differently, so you'll have to replace the entire dashboard.
and yes, the wiring harnesses from the 2 years are different, so some wiring changes will need to be done. I have comparison chart for 84 to 92 if you want a copy let me know.
Chris.
Chris.
im doing it on my 83. The only problems are like you say the VSS signal which is right off the tranny. Ill be doing it this week and let you know of any problems ill encounter
Car: 85 Z
Engine: 383
Yes, It will fit with some work. I did this lastsummer here is a link that will help you from when I did it.....Good Luck!
https://www.thirdgen.org/techbb2/sho...hreadid=186037
deadtrend1
Are you taking pictures as you go through this swap, and taking notes of what you have to do?
Your car 83 will be very similar to my 84, so once your done would you mind posting pics of what you had to do, and maybe some tips?
Chris.
Chris.
No problem .. i will be picing up the dash middle of this week hopefully if i can get up to njspeeders house. If its not absolute zero plus 5 outside .. i will start it later on in the week.
