Are these C&C T-tops?
1 Post
Car: 2009 Pontiac G8 GXP
Engine: LS3
Transmission: 6L80E
The T-top dimensions are different from published specs I have seen...but the weatherstripping and the molding looks like C&C...
1 Post
Engine: LS3
Transmission: 6L80E
The molding in the middle is damaged...apparently someone tried to break into the car (previous owner)...
TIA for the help...
TIA for the help...
Car: 08 Sierra, 08 Silverado, 91 z28
Engine: 5.3, 4.3, 5.7
Transmission: autos
the plastic where it latchs in the front doesnt look like factory t tops. but the deminsions look right to me.
1 Post
Engine: LS3
Transmission: 6L80E
There is no C&C mark on the glass (I read that there should be)...and the t-top dimensions are a bit smaller than here:
http://www.sunroofdoctor.com
This making me scratch my head a bit...
The weatherstripping appears to be the C&C type...including the red spaghetti string felt deal...
Hmmm...
Hmmm...
1 Post
Engine: LS3
Transmission: 6L80E
DOH!....they are C&C...I just visited the site I posted above...Guess I shouldn't be researching this while tired
Thanks...
Thanks...
The plastic trim/weather stripping look just like mine.Only diff is your center bar.glass secures in the groove there.On my 84Z the glass lifts like a vent window.there is also a C&C logo on the outside corner of the glass..All the C&C t-tops that ive seen are slightly shorter than G.M t-tops.The windshield header is wider(about 4in versus G.Ms about 2in).I believe this is because C&C cars start off as hardtops.When the roof is trim the header is left wider so the visors wont have to be replaced(too big).G.M t-top visors are half as wide as C&C/hardtop versions.If theyre locking.C&C t-tops use a diff key for the locks,G.Ms use the door key i believe....
1 Post
Engine: LS3
Transmission: 6L80E
Sound like your setup is a bit cooler...but tougher to find replacement t-tops for...
The next challenge is the headliner...
ive had an 83 z28 C&C car and a factory 84 z28 t tops car and i have to say that the factory stuff is better quality, but the 84 leaked and the 83 didnt, but i took care of the 84 leaks by sealing all around between the stripping and the painted metal roof of the car, used clear sealant, the C&C latching mechanism was just big a bulky and clunky and had problems
Originally posted by 88TPI406GTA
You mean remove the trim completely? or just remove it and put the grommets behind? I like that idea...
1Aauto
Sponsored Vendors
01-15-2016 06:26 AM
Thirdgen89GTA
11-26-2015 11:04 PM
