Check out my new gauges.
Car: 1991 camaro RS
Engine: 305 Carb
Check out my new gauges, just got these installed and im prety satisfied.
This pic is a daytime shot.
Car: 1991 camaro RS
Engine: 305 Carb
This is a what they look like during nighttime. The color didnt turn out right, they actually light up blue, instead of blue-esh green like the picture. and the kph isnt pink.
Car: 1991 camaro RS
Engine: 305 Carb
No, it has its own light source with it. Its got a wire running off each of the gauges, and you just wire it all up. Its like the lights are built it. It comes with a dimmer switch and you can change colors to blue or green.
Car: 1989 Firebird
Axle/Gears: ?
yeah that lighting in those faces are called EL "electro lumenescense" same kind of thing that is in indiglo watches
Car: 1991 camaro RS
Engine: 305 Carb
It got them off ebay, they were only $25.00 plus shipping. It comes with all the stuff to install.
http://cgi.ebay.com/ebaymotors/ws/eB...category=43952
1 Post
Car: 91 Z28/99 WS6/02 WS6
Engine: All 350's :)
Transmission: 700R4 & 2 Tremec T56's
I got the same ones as the original poster - they look hella sweet at night. My only problem was my own fault - wired it into the wrong yellow wire though - so I have no dash lights when the brights are on (I went from brown first, but it was going to be a PITA to get to - I'll take the time and do it right when it gets warm again)
Car: Black 1984 Chevrolet Camaro Z28
Engine: LG4 305
Originally posted by Anth's Iroc
[B]I got them to from the same seller.I had to do alittle modifying but nothin major
A little off topic but is the gauge bezel painted or is it aluminum?
1 Post
Car: 1987 Camaro Z28
Engine: 335 TPI Stroker
Transmission: Tremec TKO 500
Axle/Gears: 10 bolt / 3.42
Anth's Iroc - How do you like your setup? What was involved in the installation? How much?
Both setups look great :hail:
Car: 1984 Pontiac Firebird
Engine: modded 5.0
Transmission: modded 700r4
wow, those look really sweet! Dell91, is that 217k I see on the odometer??? I have a buddy with 279k on a 87 formula....
Car: 1991 camaro RS
Engine: 305 Carb
Mike83z-28 i put mine right beside the stereo, its got a chevy bow tie on it, and at night, it lights up, it looks awesome.
1 Post
Car: 87 IROC-Z
Engine: =350 sbc
Transmission: TH350
I painted the bezel with aluminum paint you can buy it at any auto store.As far as installationn of the glo gauges I had to take off the needles and i also had to cut the the very end of each gauge and notch it so it would fit even with the overlays you cant notice that i had to cut it with the overlays off.As far as where did i put the controls I turned the light controler all the way up set it to blue taped it up so it wouldnt short out and hid it in may dash..........
BumpaD82
02-26-2016 02:57 PM
