4th gen console to 3rd gen dash
Car: 1986 Iroc-Z
Transmission: Automatic
if you wanted to put just the center console from a 4th gen in a third gen. would the fit togeather fine or would you have to do some work??
Car: 89 formula 350
Engine: L98(350)
don't think it will work on a camaro because the radio opening is part of the center console on the 3rd gen camaro console the forth gen isn't unless for have a firebird on a firebird dash.
Car: 88' Formula 350
Engine: 358 ci TPI
Transmission: Tremec T-56
a fourth gen center console will fit in just fine if you use a radio pod from a 3rd gen firebird. there is only one easy cut that must be made if you have a manual trans. an auto trans will require quite abit of modification to the console and the shifter plate to make it work. i have a 4th gen console in my firebird. i can get pics and specifics on the cut for a manual trans. i dont know about the auto trans cuts.
ambainb
04-25-2016 09:21 PM
